Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
VX2100 record settings for slow motion playback when editing
I am interested in knowing what the best record settings are if I intend to play the action in slow motion when editing in Adobe Premiere Pro 1.5.
    Problem Solver:
  • 18 Answers
You can't ! you have to slow you footage afterwards.
Anyway, try to record with a slow speed shutter (1/30th of a second or less) to fluidify your images but if you want to slow down your footage, it's probably because the scene is "fast" and this doesn't could help you anyway !!!
Posted on Dec 26, 2008
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Recording onto a mini dv tape from Mac computer Via firewire
I have successfully recorded to a mini Dv tape from my computer however I connected my PC to the VX2100 using the RCA inputs. I have an adapter that I purchased from best buy that provides the RCA input/output. If your able to connect that make sure to...
1. Turn you VX2100 to Play/Edit mode (not camera mode)
2. Insure the program on your mac has an external output otherwise you won't be able to record.
3. See if your video editing software (if your using one) has an option for record to tape or to camera. I use Vegas Studio and it has an option for that.
Hope this helps. Good Luck!
Jun 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
I have a VX2100 and am interested to know what the best record settings are if you plan to do slow motion playback when editing.
There is no ONE setting for the three areas you stated, However, if you want the object/event/action seen in slow motion you can among other things: A) Over crank the recording speed during recording. B) Record at standard speed and slow the motion in editing. C) Add more ram and upgrade your NLE and compatible video card.
What ever you decide, make sure you have plenty of light facing the subject if possible.
Dec 18, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Slow Playback
Sounds to me that the computer is way out of date. Chances are the computer doesn't have enough processing power to support what you're trying to throw at it.
It might help stop/uninstall all other programs running at the same time to give Cakewalk the best chance of working.
Nov 15, 2017 | Cakewalk Guitar Tracks Pro 2 Classic
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Audio dropout
take it or ship it to video tech service. they will clear it and go from there. it may need some tension adustments in addition. The guy there is super cool.
Aug 18, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Red vertical smears on LCD display and on playback
Your camcorder is on a list with potentially defect CCD light sensors. Sony is replacing them free of charge. Go here for the link and free mailing label: http://www.imaging-resource.com/badccds.html
Dec 13, 2006 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
348 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
