Question about ASUS P4T-M Motherboard
Upgrading memory hi i have an asus p4t-m motherboard and i want to upgrade my memory. i know that i need rdram pc 800. but anywhere that i search they have pc800-40 and pc800-45 types.my question is, would either one be compatible, would performance be affected. right now i have 800-45 installed but memory websites that i searched say 800-40 is needed,so now i am confused
  • 449 Answers
Pc 800-45 is also compatible. you can get that one.
Posted on Dec 18, 2008
I need changes my memory 2 pcs @ 1GB DDR1 PC3200 with 2 pcs @ 2GB DDR2 PC6400 in Asus P5VDC-MX Motherboard. please advice. Thank you
Number of Memory Slots: 2×184pin + 2×240pin
Memory Standard: DDR 400/DDR2 533
Maximum Memory Supported:2GB
PC6400(DDR2 800) is not supported by your motherboard. Also max memory is 2GB. PC4200 is the fastest memory you can install. There might be a BIOS update available from ASUS website to increase the speed but you would have to check the site.
Dec 01, 2009 | ASUS P5VDC-MX Motherboard
Looking for the manual for a Gateway 700S PC. Specifically 2 questions ... 1) how do I open the ATX tower case? and 2) what EXACT memory specs do i need to upgrade this unit from the 256MB that it came...
for the memory upgrade, your system used RDRAM RIMMS.
it supports the following memory modules (which must be installed in pairs).
and as for opening the case, you there should just be ~2 screws on the side panel away from the motherboard ports that you can remove and it will slide off, or there might be 1 or 2 thumb screws.
64MB Module 64MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-136 128MB Module 128MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-079 512 MB Kit 256MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-081 64MB ECC Module 64MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-134 128MB ECC Module 128MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-080 512 MB ECC Kit 256MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-082
Jun 24, 2009 | Gateway 700 X PC Desktop
I want to upgrade my procesor to faster procesor.
Upgrading processor is not likely a practical solution; find out the motherboard manufacturer and contact their site for more information. As to upgrading the motherboard, you'll have to know what kind/size of board your system will require. If you don't have lots of experience, this process is very risky.
Frankly, the cheapest way to upgrade your computer is to buy a used and working product with Windows XP already installed. Go to http://craigslist.com, select your city, and search for a brand name you trust. I've bought DOZENS of used computers very cheap that way (I'm writing this on a $2,200 Dell Latitude D620 I bought fiv months old for $500, who needed the cash!)
Mar 30, 2009 | Gateway Computers & Internet
Memory Upgrade
Depends of your buget, Extra 4 GB DDR2 800 = $35 (total 8GB) I Have 4GB installed now seems fine, but all of this is necessary?
what application do you need to work?
Mar 27, 2009 | Computers & Internet
Processor upgrade
Here is a link to the manual for the motherboard.
http://dlcdnet.asus.com/pub/ASUS/mb/sock423/850/
p4t-m/p4tm-100.pdf
The manual doesn't really say what cpu speeds the board supports.
1.4 ghz was about the fastest processor speed when the board came out. My guess is that a 2.0 ghz cpu may not work.
It would be a slight improvement over the 1.4 ghz cpu, but not a huge difference.
Jun 25, 2008 | ASUS P4T-M Motherboard
PC don´t boot after upgrading BIOS
Have you tried to reset the bios by removing the battery for around 10 minutes then putting it back in??? i would try this first.
If this is unsuccesful then i really suggest you have burned your bios doing the upgrade... you might be out of luck on this one
May 02, 2008 | ASUS Intel 850 Chipset P4T Motherboard
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Dec 19, 2007 | ASUS M2N-MX Motherboard
Memory Sticks.
No you cannot fit sdram, they will not fit. Go to the link below and it will explain what memory you have and if you use the pc to go to thie link there is a memory advisor tool to the right of the page which will search your pc and advise you as to what upgrade you can have. http://www.crucial.com/library/ddr_vs_rdram.asp
Apr 11, 2007 | Intel D850MV Motherboard
ASUS P4T-M Motherboard Logo
129 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
