Question about Dell Latitude D600 Notebook
Usb my usb internal curcit was not work.how to use another port ? i mean [docklng system or another port with adapater cable ? which it easy and low prices because i from myanmar poor man. if you reply very thank to you.....
    Problem Solver:
  • 10 Answers
Hi there , not shore if this will work or not but with some usb mice you buy you get a ps2 adapter for it , you could try this and run the usb through the ps2 port on the back .
Posted on Dec 20, 2008
Seatools test code 606060d0 hat does it mean
this code usually suggest that this is lba (logical block addressing) issue, i am suspecting your pcb board being at fault or usb port or usb cable or power source. i assume that this is on external hdd?
asking that sort of the question you should provide manufacturer of hdd, internal or external, what wer the symptoms, what is the size of hdd, what o/s you use, this is helping in providing detailed and correct solution. as you supplied only fragmentary data - only generic solution can be provided.
before you do anything else, check your power supply, check your usb cable and check usb port, check all three on another computer as well.
if power supply, usb cable and usb port are ok, and hdd is out of warranty, then i would suggest opening of the case and connecting hdd directly to the computer via sata cable. and internal power supply.
if hdd works correctly, switch to power supply supplied with the casing, if you can read the data, that way you will exclude power supply as culprit, it works...
that will left only and only pcb and usb port/cable.
hope this short info will help you - do not forget to vote...
Mar 02, 2015 | Computers & Internet
Ultra SuperSpeed USB
usb speeds b> A USB, or Universal Serial Bus, is the brainchild of Intel developer Ajay Bhatt. USB is useful for transmitting data and power to devices. USB cables are widely used in 2010 to connect computers to such devices as printers, cameras and flash drives. While the USB port was initially developed for computers, it has become standard for video game consoles, smart phones, PDAs; it can also function as power cords for these devices.
Unit Load Capacity
USB comes in 1.0, 2.0 and 3.0 versions. Each provides between 4.75 and 5.25 volts (V) of power that travels between one wired line. Various devices may draw this amount of power from that single, wired line. A maximum of five unit loads can be drawn from a USB 2.0 port, however six unit loads can be drawn from a USB 3.0 port, making it capable of delivering more power to devices. USB devices are configured to support a minimum of 100 milliamps (mA) times the number of powered ports it contains (200mA for one port, 300mA for two ports, etc.). b> Charging Devices b> Many devices can draw power to recharge their batteries or can function off of power currents running through a USB port cord. Superspeed USB ports run off a 3.0 platform and optimize power usage to provide the minimum amount of energy the device needs to recharge or run. New powering modes allow USB ports to supply power and communication (data transfer) concurrently. A USB Charging Downstream Port can supply up to 1.5 amps (A) at low-bandwidth transfer rates and 900mA at high bandwidth rates. A portable device such as a phone or PDA can draw up to 1.8 A from a Dedicated Charging Port on a USB 2.0 or higher device. In 2009, major cell phone manufacturers like Nokia, Motorola and Samsung agreed upon a standard, universal micro-USB charger for all their phones. In time, this will eliminate the need for manufacturers to provide charging cables with their phones. This micro-USB device has been adopted by the International Telecommunication Union as its universal mobile phone charger solution. When a device requires more power than can be delivered by a single USB port, that device may be charged with a multi-ported USB. External hard drives, for example, can be powered by a USB cable that connects to an external power supply on one end and to a device on the other. b> Powered USB b> A powered USB is a self-powered USB that uses additional power lines than standard USB ports to deliver more electrical current to a device. It uses four extra pins to supply 6 A at either 5 V, 12 V or 24 V to attached devices. Powered USBs are used to power retail devices like barcode scanners, printers, pin pads and signature capture devices. These USBs consist of two ports: a top one which accepts a USB cable and a bottom one which accepts a power cord. The powered USB allows devices to draw more power from a USB and not require an external power source to operate.
USB Power Options
b> According to Everythingusb.com, the Universal Serial Bus (USB) is a concept that was originally designed as a connection for smartphones to computers in the 1990s. Since then, the USB has evolved from the older USB 1.0 and 2.0 designs to the faster USB 3.0 model, which is also called the "Superspeed USB." A benefit of USB is that it can be used to power devices without requiring any additional power cables or plug packs.
Low-Power USB
Low-power USB devices typically consume 100 milliampere or less from the USB bus. This is called a single-load unit. USB 1.0 and 2.0 devices have a single-load unit of 100 milliampere, and for the newer USB 3.0, the single-load unit is redefined to 150 milliampere. Low-power USB devices can be plugged into any USB host or hub port. Low power bus powered devices use the so-called "V bus" pin to draw its power and run on a voltage of between 4.40 volts up to 5.25 volts. A low drop-out regulator is required for most 3.3 volt devices. b> High-Power USB b> High-power USB 2.0 devices consume between 101 milliampere and 500 milliampere (1 to 5 load units) to run on. USB 3.0 supports power consumption of up to 900 milliampere (6 load units). These devices can be plugged in to any USB port, but if you are using a USB hub, the device will only be able to draw 100 milliampere unless the hub is self-powered. High-power USB devices run on a minimum of 4.40 volts. b> Self-Powered USB b> Two types of self powered USB devices exist: true self-powered devices that rely completely on their own power supply, and hybrid self-powered devices that also draw some current from the USB bus. Hybrid self-powered USB devices typically draw up to one load unit from the bus and use their own external source for the rest of their power. Most of these devices have a safety feature to ensure that they don't try to draw more power from the bus, should the external source fail. High Speed USB Port Since 2002, Microsoft has supported high-speed USB ports in the Windows XP operating system. Prior to 2002, computers and operating systems used the USB 1.1 standard, with its 12Mbps maximum data transfer rates. USB 2.0, also known as "Hi-Speed," pushes the maximum data transfer speed to 480Mbps. To take advantage of the higher speeds, you'll need to install a USB 2.0 card in your computer. In most cases, desktop users will need to install an internal card, while laptop users with PC Card or ExpressCard slots may install external cards.
Purchase an internal USB card or internal USB drive bay. Shut down your computer. Remove all cables and peripheral devices. Remove the left side panel (when facing the front of the case). Remove any screws or adjust any latches. The method of removing your side panel will vary according to the type of case you have. If you are unsure of how to remove your side panel, see your case or computer documentation. Attach the anti-static wrist bracelet's clip to a metal object. Strap the bracelet to your wrist. Locate an empty card slot. Remove the card slot cover by unscrewing the screw and lifting the cover, if applicable. Line up the hardware with the slot to ensure that you are inserting it in the correct direction. Insert the card into the slot until you hear a click. Do not force the card. Remove it if you're having problems. Then line up the card with the slot again and try to insert it again. Secure the card into the slot with the slot cover screw you removed earlier. Replace the side panel. Screw in any screws you removed earlier. Attach all cables and peripheral devices to your computer. Restart the computer. Windows will automatically detect your new high-speed USB port. b> Install an External Card b> Turn on your computer. Locate an available PC Card or ExpressCard slot. Insert the card into the slot. The card will click when seated. Allow your operating system time to detect the high-speed USB port and to install the drivers required. Hope this helps.
b>
Oct 06, 2012 | Ultra Products Ultra U12-40528 SuperSpeed...
Printer not talking to desk top.
Please check usb cable first, make sure that it is ok. Then check usb port,move the usb cable to other port. Then check if usb cable and port are ok, try to connect other printer or device by using that usb cable and port. If works well means the usb port on printer got a problem. But if still not work the problem could be on usb cable or usb port on computer.
If you are sure that both the printer and computer are ok, try to reinstall the printer driver. Good luck!.
Source: Printer Clinic - Where printer problem get solved
Sep 18, 2012 | Canon Pixma MX310 All in One
How do I transfer my photos from my camera to tv
If your TV has ab USB port then you can copy the photos from your camera to your computer and the copy the photos from the computer to a USB flash memory stick.
Then insert this memory stick into the USB port on the TV and select the USB input to display your photos.
May 28, 2011 | Computers & Internet
It wont show up
Have you tried alternate usb cables and usb ports on your system? have you tried a different system? If that doesn't resolve the issue- you have a dead external drive- if swapping the cables works, you have a dead cable. If swapping the port that you are connecting to- it could be the port is bad, or the port is a low power port. If swapping to a second system works- and none of the ports on the other system works- then the system will need service- either for reinstalling windows, or a replacement motherboard since the USB has failed.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 03, 2010 | Western Digital My Book Essential 1TB...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Any advice for getting the usb cable to work properly with my Hue when trying to connect to my PC thru Alltell QuickLink Mobile? I keep getting the box saying the usb has malfunctioned. Have exchanged...
It sure is frustrating. USB has Malfunctioned does not necessarily mean the USB cable has malfunctioned. It could also mean the USB port in the PC. Go to Start->Ctrl Panel->System->HardWare->Device Manager. And check the USB Controllers right at the bottom of the list. Uninstall and reinstall the USB ports.
Aug 07, 2009 | Samsung Hue (SCH-r500) Cellular Phone
My sony walkman nwz-e436f was working fine and all the sudden its taking no charge from any usb ports
Check the connector of the USB Ports and Sony. Also it's internal battery require replacement.
Jul 06, 2009 | Sony NWZ-E436F MP3 Player
Hanging problem
ya u are rite connect the cable thr will show that mtp connected then transfer music but is it hanged on than this means ur usb port has problem than try to use different usb port...make it sure u are using rear usb port of ur pc.....hanging problem is only due to breakage in transfer of data that is only due to low usb port...i have same problem i always connect my media player in front usb port of pc then i got to know that it has low speed than i connect it to rear of usb port in my pc that is high speed port than it worked smoothly
Sep 02, 2008 | Samsung YP-K5JAB MP3 Player
USB port is not working under windows xp sp 2
Usb suffers from electrostatic charges problems. unplug your PC power cable from outlet for 20 mins and plug it back.
regards
Mar 02, 2008 | Soltek SL-75FRN2-L Motherboard
Dell Latitude D600 Notebook Logo
83 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
