I have a 1999 lincoln town car after setting the alarm about 30 minutes later the alarm is tripped when i reset it it remains set and is all ok is it a voltage problem and how do you fix it thank you
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
I have a 1999 F150 and just installed the 5701. After about 35 minutes of being armed, the alarm gets tripped.
