Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Audio fade In the last week I have noticed after the TV is warmed up, the volume begins to decrease. I keep turning up the volume on the TV until eventually it is up all the way and I can barely hear the audio. If I turn the TV off and back on, the volume goes back to normal level, but eventually the problem comes back. If I listen to the audio through my surround sound system, no problem. Any suggestions?
    President:
  • 3,130 Answers
If there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Posted on Mar 29, 2007
SOURCE:
Volume fades to zero
I would try to run new wires for 12v main and memory supply and make sure the grounding wires are firm all over. good luck
Dec 08, 2013 | Car Audio & Video
My Kenwood RC-150 Learning Remote. How do I delete a programmed key
Remove the batteries and let the remote sit idle for a time until retained memory fades. Reinstall the batteries and start over again.
Nov 16, 2013 | Kenwood Remote Control RC-150...
Volume control
your volume control encoder is dirty and either needs to be cleaned or replaced.
Nov 10, 2013 | Memorex Nostalgia 4-way Stereo Shelf...
Volume Problems: Panasonic TH-42PZ700U
please could you send me tips of what the problem of my plasma keeping stuck pixiel panorama LCD Tv model 42LC68T
Mar 29, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
FRONT SPEAKERS HAVE NO AUDIO AND REAR SPEAKERS IMEDIATELY FADE
check all your wires in the front speakers and make sure there coverd
Dec 06, 2008 | 1992 Mercedes-Benz 190
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Audio volume level
Hi, I'm guessing your turning up the volume on the TV box to control the volume of your speakers. By doing this your only controling the audio strength coming out from the TV box.
What you should be doing is turning up the volume on your TV or amp feeding your speakers rather than the direrct TV box. The level of the speakers may have been reduced form last week (other people messing about with your equipment?) which is the reason why you have to turn it up to 30 rather than 10.
Another problem could be a loose audio connection from you direct TV box to your amp or TV. Have you tried a different source such as a DVD player, and does the sound on that seem alot quiter than before? If the volume of this is alot quiter also it could be a problem with your speakers.
Hope this helps.
Nov 01, 2008 | Televison & Video
Blue screen
this problem is due to blue video circuit. 1 Please check supply to blue video ckt. 2 check crt base for loose. 3 check loose contact & parts related to blue cathode. 4 blue signal coming from processor to blue video. 5 processor it self. 6 at last if tv is very old than check crt also.(possibility is rear) hope this will help.
Oct 03, 2007 | Sharp 32C-240 32" TV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
