Question about HP Office Equipment & Supplies
I can receive faxes but I cannot send any. The error report #442*
    President:
  • HP Master
  • 990 Answers
Dear sir; I like you to change a cable to try it ,let me know what's result. good luck,
Posted on Dec 18, 2008
My faxes are going through but I get error tx reports. Why is this?
because the fax is not going through as transmitted
the fax report will have OK if it was sent and received correctly
call the recipient of the fax direct and ask what the fax looks like or if they got it alright
Oct 24, 2016 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Wont send message. Error no 442
This error indicates that the receiving machine (receiver) cannot receive the fax you just sent. The reasons might be unexpected shutdown of the machine (Receiver's machine) just before it completely received [or partially printed] the file you had sent or power failure during the process.
Another reason is, when we send color fax from Hp machine to another Machine (non-hp), this happens due to incompatibility issue.
Solutions are;
1. Restart both the machine after deleting the recently sent/received fax.
2. Send black and white only, not color.
3. Try again after the phone line seems not much busy which means when there's better transmission capability.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have an HP Lazerjet Model 3030. Recently I have
Here is a link to Hp for your Laserjet 3030. Look under Troubleshooting Fax Codes and Trace Reports. Click on 'Fax send and receive codes'. Scroll down the page to locate each code that you mentioned. I suggest calling your fax number from a cell phone to see if the fax line is clean (doesn't have any noise or static other than the "handshake digital tones") If it does have other NOISE....have the phone company check your fax's phone line for troubles. Let me know.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&prodSeriesId=378056&objectID=c00062808#A5
Nov 18, 2009 | HP LaserJet 3030 All-In-One Printer
Trying to set up fax to print when sending fax
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
● Every fax error (the factory-set default)
● Send fax error
● Receive fax error
● Every fax
● Send fax only
● Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
Sep 24, 2009 | HP LaserJet 3390 All-In-One Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
