Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
Timer on stove keeps going off
GE stove JBP36GO42
timer went off in middle of night, had not been set. Turned off. About 24 hrs later did same thing. turned off. an hour later it came back on (this is in middle of night) husband unplugged stove so it wouldn't come back on. should we replace timer? is it worth replacing timer due to age of stove. if we replace stove, do you recommend the flat cook top? Thank you.
  • 3 more comments
  • ubcdbaker Dec 20, 2008
    The timer on my old GE stove/oven goes off at odd intervals, even though I haven't set it!
  • Anonymous Feb 01, 2009
    my stove is giving a buzzing sound i want to know if it is the timer
  • Anonymous Feb 15, 2009
    timer just started going off for no reason. cannot make it stop
  • Anonymous Apr 08, 2009
    My older model oven timer keeps going off in the middle of the night as well, getting really annoying!
  • Anonymous Apr 13, 2009
    My timer keeps going off for no reason.
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Posted on Dec 18, 2009
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Posted on Dec 21, 2009
SOURCE: i have ge model 15119 24 her timer and need help
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Posted on Dec 01, 2010
SOURCE: i need instuctions on how
See both GE strip timers to identify product:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
GE 15077 digital or programmable strip timer manual
http://waterheatertimer.org/pdf/GE-15077-Manual-eng.pdf
If this manual does not match your timer, add a comment.
Posted on Dec 16, 2010
SOURCE: I have a GE heavy duty 24 hour timer model no.
The middle dial is the current time and it works like oldy timer does you set when you want it on then the timer will spin according to the time of day Duhhh
Posted on Dec 18, 2010
I need to reset the timer on my 633T Krystal Clear pump as we have unplugged the power and we can't get the timer to work.
You know the timer can only be programmed once and it is 24 hrs after the last time it ran. So turn it on at the exact time of day you want it to run every day, set the dial to how many hours to run and walk away. It should start up automatically 24 hrs later each and every day (as long as you have the on switch set to the timer position)
Jul 12, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I have a GE heavy duty 24 hour timer model no. 15075. I need to know what the dial in the middle needs to be set at and why does it spin? What purpose is the spinning dial serving. If it did nothing I...
Mar 15, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Microwave quit, now has high pitched 'alarm'' going off
Can you turn the breaker OFF. or will this affect the other things on that socket?
Feb 03, 2010 | Microwave Ovens
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
I have a Jenn Aire SVE47100 that keeps beeping
my stove did the same thing. I turned on the downdraft fan and it quit. I think it overheats the board when you are baking. try it and see if this helps.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Igniter "clicking" on its own...
new spark module. Most stoves use a common part.
Jul 25, 2008 | Tappan 24 in. Freestanding Gas Range...
Defrost timer
The timer has a rotation 24/7 every 6 to 8 hrs. depending on timmer set up it goes into defrost... there is No way to adjust when it will defrost.
Sep 19, 2007 | GE (GTS16BCS) Top Freezer Refrigerator
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
1,240 people viewed this question
Top General Electric Hardware & Accessories Experts
Marvin
Marvin
Craig Butler
Craig Butler
ray gallant
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
