Question about Xerox WorkCentre M118 Black and White Copier
Trying to Print Tally Report
I'm trying to print out or write down the running tallies of the different accounts set up on the copier. The Serial number of the Xerox Copier is: 5011041 and I believe the model is: FWT-008489. I got a link to the Xerox website but they want me to register in order to obtain the numbers but our copier isn't even networked to the internet so online tallies would not be an option. Could you please tell me step by step how to obtain these numbers?
  • cgunn Dec 18, 2008
    Thank you! It worked!!! :)
    President:
  • 2,072 Answers
This should get you to the right area. I think you are asking to read the auditron accounts. This is the reset, which will allow you to see the copy count for all accounts set up.
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. When the Auditron feature is enabled users need to enter a password to display the System Settings screen, or use the Copy, Fax and E-mail features on the machine.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Posted on Dec 18, 2008
  • Rick Kasper Dec 18, 2008
    Or this may be what you want.
    The Print Report / List feature allows you to print various reports and lists for each non-print job.
    1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
    2. Press the middle [Select] button below the Display Screen to display the Report / List information.
    3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
    Note: The WorkCentre M118 does not contain a fax board. Due to certain fonts being stored on the fax board, the WorkCentre M118 may not be able to print all of the Auditron reports. This does not apply to the WorkCentre M118i because this model contains a fax board.
    Sent Report
    Lists the last 50 fax transmissions and e-mail sendings. The information reported includes: the recipient name, the transmission time, the modes and the transmission result.
    Received Report
    Lists information of the last 50 faxes received. The information reported includes: the sender name, the reception time, the modes and the result.
    Fax Program
    Prints detailed information for each Fax Program. The list includes: Program name, the setting for each feature, the recipient name and the Speed Dial code.
    System Settings
    Confirm the status of settings on this machine. The information reported includes: Serial Number, Auditron details and Copy/Fax/e-mail settings.
    Private Mailbox
    Prints out the box names in numerical order of box number.
    Bulletin Board List
    Prints out a report as a list of registered bulletin boards. The information reported includes: Titles of registered documents, date and time of document registration in numerical order of bulletin board.
    F Code Settings
    Prints a report detailing information about the F Code receive settings for the mailboxes registered. The information reported includes: Reception information such as the F Code or password, or information about the forwarding destination.
    Copy Meter
    Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
    Address Book
    Lists the contents of Address Book.
    1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
    2. Press the [Start] button on the Control Panel. The Report / List will print.
Tally open but not print
first select the report in tally what u want to print through print option (Alt P) and then go to printer selection through Alt S (in this option u select the printer whichever u want)
Dec 11, 2010 | HP PSC 1610 All-In-One InkJet Printer
Tally MIP480 Mobile Printer: would not print...
Bad error description. However, maybe you just have to set up the correct printer port (USB, serial, etc.) in the printers menu.
May 16, 2010 | TallyGenicom Tally MIP480 Mobile Printer
How to automatically import data from tally to excel. Want to display auto imported data in sharepoint.
Import TALLY Data / Export TALLY Data
Tally allows users to Import data from other software's as well as Export data from Tally to other software's. Tally allows users to Import and Export in ASCII, SDF and XML formats. XML is now the most widely used format of exporting data in the world. Any transactions can be exported from Tally and imported in other software after suitably altering the current structures to accept Tally data structure. The reverse is also possible by writing a small TDL program to accept the data from other software's. The data that is to be imported into Tally can be in either XML or DBF format. Easy Tally data transfer or Tally data migration from Tally 4.5 & Tally 5.4 to Tally 6.3 , Tally 7.2 , etc.
ODBC COMPLIANCE ALLOWS OTHER PROGRAMS TO USE DATA FROM TALLY DIRECTLY. E.G. : MS-EXCEL :
ODBC - OPEN DATABASE CONNECTIVITY
Tally is now ODBC compliant. Hence, any program like MS-Excel, Oracle etc that is ODBC compliant can use data from Tally. Here, data connectivity is dynamic i.e. any new updation in Tally is reflected in other ODBC Compliant Software immediately. Now, with ODBC facility the user can extract data out of Tally and design his own report formats in other ODBC compliant software's.
Procedure :
Now, Load Company -> specify period -> minimize Tally -> Open a new Excel file -> select data -> select 'Get External Data' -> select New database query -> choose Data Source
Tally connects to data source and displays Tally Wizard query screen -> select the columns you would want to include in the query.
Once all the columns are selected, the user returns to excel and excel displays all the columns selected
Graphical Analysis of Tally Data
Sometimes, pictures can say better than figures. Tally also provides graphical (Bar graph) analysis of data. The user can do a graphical analysis reports like Sales register, Purchase register, Ledgers, Funds flow, Cash flow, Item registers etc. This helps the user in deeper analysis of data. In Tally, a graphical analysis can also show month wise graphs for the year in comparison with any other period. This will help the management in quickly locating the highs and lean periods in a financial year and hence be better prepared for difficult times.
Web Enabled
Tally ees 6.3 is now Web enabled. This will help the user in reducing his paper work further. Now, report in Tally can be e-mailed directly from Tally. It is not just reports, but even invoices and purchase orders can also be e-mailed directly from Tally. Hence, the user does not have to send printed invoice or purchase orders from Tally.
Procedure :
Select any report (e.g. Balance sheet) -> select Alt+M (E-mail) -> specify all details as required by Tally
Ability to Publish Reports and Documents on the Internet
Now, Tally allows users to upload reports on the web site directly from Tally. So companies that would want to publish reports on the web site can do so directly from Tally. Many companies would also like to publish their price list on their websites along with the product they deal with.
Procedure :
Select any report (Profit and Loss A/C) -> select Upload (Alt + O) -> specify all details as required by Tally.
Direct Internet Access
Tally now offers direct Internet access. A Tally user while working on Tally can directly log on to tally website get details of all the facilities offered by Tally. The user can also download the latest releases of Tally 6.3 as and when available. Tally website also offers a facility of Tally Chat. Any user can now chat with a Tally representative and get any information regarding Tally.
Procedure :
Start Tally -> now, from any screen select Web Browser (Alt+W). Tally now takes you to the Tally Web site.
Print Preview
Any user would ideally like to view format of reports / Invoices / Vouchers before printing the same. Tally now offers a facility of print preview. Now any report can be viewed before printing or before it is mailed. Once Tally shows the preview the user can either opt to print or mail the same.
Apr 15, 2010 | Microsoft Office Excel 2007
How to set fanfold 8.5 x 12 page in Tally 9
when you giving print command choose the printer and go to printer option and choose the paper type then give the print command .
Jan 20, 2010 | Tally T2245 Matrix Printer
Data overrun
I would hazard a guess that the printer is connected via the serial interface.....
If this is the case you either have a problem with you serial interface settings or the serial cable pin configuration does not match the printers serial interface pin configuration..
I would recommend printing a MENU print on the MT661 and check the serial interface settings these NEED TO MATCH THE HOST SYSTEM
To print a menu print.
  • Put the printer OFFLINE
  • Press MODE
  • Press the DOWN ARROW to HELP
  • Press ENTER
A menu print will be printed look for things like Protocol, Baud Rate, Data Bits, Stop Bits etc
These need to be set to match the host computer system.
Jul 07, 2009 | Tally T2250 Matrix Printer
How to find tally 9 short-cut keys
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
May 30, 2009 | Computers & Internet
I am not print from tally software it is getting failed
please check that u select the proper printer before preceeding for print command. Also check that the printer connected to ur system is ur default printer.
Jan 10, 2009 | HP LaserJet M1522nf Multifunction Printer...
How to change column in tally
change the portrait form of paper setting to landscape
Dec 17, 2008 | Tally T2250 Matrix Printer
Service manual
Pls help me I have a lot of printing work to be done be4 tomorrow
I have Tally 6125 printer that I use to print bills for the community about 30 000
Copies a week just yesterday that is start to print these things when ever you give any print command
Main CPU Software: PSI 21 2.2d
Ctrl CPU Software: Control E3.12
Interface : serial Parallel
The Tally Printer can print can print this messages in 1 min without a spot
Pls want can I do to stop this
Dec 13, 2007 | Tally Office Equipment & Supplies
Xerox WorkCentre M118 Black and White Copier Logo
429 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
