Question about Zenith A50M84W 50" Rear Projection Television
Very poor resolution
I bought a used big screen w/o the original remote control i'm having a hard time adjusting the proj. set up in the menu. I'm able to adjust the white lines going left to right, but I have to press the source button on the remote to adjust the blue lines going left to right and whaite and blue lines goin up and down. Do I need the original remote or can a universal remote work? The TV is 9 years old. Thank you. Sniley
Go to ebay and you can get the zenith remote for that tv for 20.00 dollars because i got a new one from ebay
Posted on Jun 20, 2008
    President:
  • 1,284 Answers
Your best bet is to get a Zenith universal remote control.
Posted on Apr 14, 2007
Poor resolution hard to read screen
Switch to a more advanced monitor... if its a desktop we are talking about. or adjust the resolution option on the PC by goin to display setting. to go there (for windows) go to the start menu and tipe display. there you adjust the resolution. if you are in a mac
  1. Choose Apple menu > System Preferences, click Displays, then click Display.
  2. Select Scaled, then select one of the scaled resolution options.
Feb 27, 2017 | Hard Computers & Internet
I have a Sanyo Flatscreen, the original remote was lost. Now when I turn on the TV the picture is to big to fit. HOW do I adjust it without the remote?
use the menu button on the side of the tv
that brings up the screen menu
using the channel and volume buttons move around until you find aspect ratio
find the one that fits the screen and press the menu button to save and exit
it could be a pixel setting so find pixel settings while the menu is on the scree and adjust to the correct pixel setting
there are plenty of remotes for tv units on e-bay
all you have to do is select one that is for sanyo led/lcd tv's and read the details to see it it works your model tv
Oct 01, 2016 | Sanyo Televison & Video
How to I adjust the settings of a TV with a universal remote? I am using this TV as a computer monitor.
Firstly having tried TV's has a computer monitor, I personally wouldn't recommend one for that purpose. The screen appearance will never look as good as a proper monitor. Even a second-hand monitor will give you better picture quality, plus it will shut down when you power the system down.
Universal remotes have to be set up with the correct code for the make of TV and model. Not all codes will work all functions. Unless you actually know the correct code for your TV try all the other codes for the brand. Choose the best one.
Again the "Universal" on makes of remotes referrers to the fact you can get the basic functions for all makes of TV. It does not mean that it will work ALL functions on all TV's. The more expensive "universal" remotes will do more functions, but nothing will beat the "original" remote.
Dec 28, 2015 | Sharp Aquos Televison & Video
Blu ray shows the "Blu ray Disc" Logo on TV screen and then just show a black creen
Hi! and welcome to Fixya!
It looks like your tv is unable to handle the output video resolution from your bluray. The reason why you do not have picture on the tv screen after the bluray disc logo appears.
You can follow the instruction below to set the video resolution on your player to its lowest resolution:
1. Using your bluray remote control, press the following buttons in order... STOP button (press and release) ....HOME button (press and release)....POP UP/MENU button ( press and release )
Note: press the buttons in order with 1 second interval. Make sure tv and bluray are ON when you try this. If first attempt nothing happens, try this again.
2. When the home menu screen appears after doing the above instruction, you can set the video resolution again manually. Follow the instruction:
Using the BD remote control press HOME button > then go to SETUP > select screen settings > then change OUTPUT VIDEO RESOLUTION to Auto > change also 24P OUT to 1080P // set the BD-ROM 24P OUTPUT to Auto
The next time you turn on the bluray player you will have picture again.
Let me know if this works!
Oct 24, 2015 | Sony Televison & Video
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
Apr 06, 2012 | Panasonic CT-36D32 36" TV
Lost remote for emerson lc320em8 32 in. lcd tv, how can i adjust the screen mode to get full screen without the remote?
Hello
It is immpossible to set its screen resolution or screen size, without it remote control. Try to get one original remote control, from the authorised service center for Emerson at your town, or buy a universal remote control, which have setup codes for Emerson TV with it. OK.
Feb 09, 2012 | Emerson LC320EM8 32 in. LCD TV
I have a 19in Emerson Flat Screen TV that I am using as a PC Monitor and it isn't using the full screen. How do I fix it to use the whole screen?
You might not be able to. If the screen size doesn't adjust with the wide/view mode/picture format button on the television remote control you have to change the resolution on the pc. You right click on an empty spot on the desktop, choose properties, and then choose the settings tab. A lower resolution will cause the image to fill the screen but the icons get really big. The image isn't as refined. However you may be able to play around with it enough to find a good enough resolution and a view mode with the Emerson remote that will work out for you (a combination of the two).
May 31, 2011 | Televison & Video
I bought new monitor Compaq S1922a and picture stretched horizontal. I have HP intel with Vista. How to adjust VGA to make picture normal?
if the whole image is too long you can adjust it from tthe image driver ..it will be in the right side on the task bar near the programs that are opened all the time ..and named like the video card you are using and usually will display when hoovering the resolution in use..open the resolutions and choose one that fits best...and confirm ..
To adjust just the the picture from the desktop ..right click on the desktop..properties..and desktop...in there choose the desktop image ..or change image ..and you will have 3 possibilities for adjusting the picture to fit..center ...stretch..and tile.. see them one by one ...if non of the stile will make it visible in a normal way ..then you should change the picture,,and choose a wallpaper that it is in the same form and big enough to fit....
T change a picture on the wallpaper it is enough to right click on it when its opened ..and choose it to be set as wallpaper from the list of tasks...
May 31, 2010 | Computers & Internet
Everything on my compaq presario cq50-215nr laptop got really big after i accidentally hit a couple of buttons on the keyboard and i dont know what i hit. how do i make them go back to normal size
Choose Screen Resolution For higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpg Control Panel: Display: Settings tab: Screen resolution
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Blurry partial picture on a 42" rear proj tv
There may be dust on Lamp or at front screen. why dont you open rear cover of TV and give a close look?
May 28, 2008 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
143 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
