Question about Brother MFC 210C All-In-One InkJet Printer
LIGHT FLASSING CANT PRINT
DCP330C PRINTER RED LIGHT FLASHES CANT TURN IT OFF CODE ON LCD SAYS UNABLE TO PRINT CODE 50 HELP ME! dont need ink all doors r closed no paper stuck but i am.
  • 2 more comments
  • hyrax Dec 11, 2007
    all lights are flashing and cant print
    brother hl2040
  • ssquirrel Mar 14, 2008
    2040 printer
    after paper jan cleared red light keeps fflashing cant print
  • Bakthan Mar 15, 2008
    When connected for the first time all the LED indication lights (toner,drum,paper,ready) are glowing continuously.
    0 lights
  • Anonymous Jul 10, 2008
    Red light flashing, can't print, no paper jammed. Even after disconnect power. Frustrating.
  • 832 Answers
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Posted on Sep 09, 2007
Brother-2040 printer has all lights flashing at one time. How do you fix it?
Posted on Apr 26, 2008
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I have an HP Photosmart 7260 printer that my cousin gave to me used so I have no manual. I've replaced both ink cartridges and am trying to print. When I send the print job, a red light begins to flash...
Can you see any symbol when the red light flashes? or any message pops up on your computer? Since your problem's description isn't very specific, I am unable to assume myself. If cartridges are replaced with new ones and the problem persists, it's possible that there's paper jam or carriage jam or contacts on the printer is bad/dirty. While the machine is On, lift up the front access door and try moving the carriage manually. Please follow this LINK to clean the contacts.
Please post back with more specific details so that I can help you better. Good Luck.
Feb 18, 2011 | HP PhotoSmart 7260 InkJet Printer
Print unable 4F
nandkjwatson,
Good day!red light flashing causes some problems on your printer.Like empty inks,no paper,hardware error.Be sure to check all ink cartridges if its full and if all chips are good.Be sure to have paper loaded.
Regards,
Mastergani
Jul 06, 2010 | Brother DCP 130C All-In-One InkJet Printer
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not balanced.to check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Feb 16, 2010 | Epson Stylus R290 InkJet Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Printer not working
Red inkout1.jpg ink light flashes One of the cartridges is low on ink. Check the message that appears on your screen to determine which cartridge is low or follow the instructions in Checking the Ink Supply. Make sure you have a replacement cartridge.
Feb 12, 2008 | Epson Stylus C86 InkJet Printer
Epsonstyluscx3810printer
try reseating the ink cartridges
if you still get the red ink error light - call EPSON with the date&place of purchase of the said inks
Dec 30, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
612 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
