I have a acer 2423wxci laptop and would like to connect to tv. I have usb ports and vga port on laptop and a s-video port on tv. How would I connect the two
  • 449 Answers
Hello, vga port or no port you will ned to have a tv card or tv box on your laptop that will be installed by a software. it is this software that will install the tv programme that you will open to view the television
Posted on Dec 18, 2008
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Can i connect my pc which is acer aspire 4720z to my LCD TV WHICH is LG22LH20R? if so which port/data cable i have to use??
The LCD TV does not have the software installed on it to integrate with the Pen drive. That is why. Pen drives are meant for input and output of data via computers with USB ports. The pieces of software required to make a computer recognize and interact with a Pen drive (or indeed any other external flash, solid state or hard disk drive based external storage devices) are USB and Storage Device Drivers built-into a computer's Operating System. Your TV does not have such drivers installed on it because it does not have an internal Storage Device to interact with external storage devices.
Your notebook can connect to the LCD TVs VGA Port by connecting a VGA Cable from the Port to the Notebooks own VGA Port -> press and hold the Fn key bottom left of the keyboard -> press the Function key at the top of the keyboard bearing the image of two monitors -> release both keys -> use the TV's remote to select Menu -> Input/Source -> PC.
Nov 15, 2011 | Acer Aspire 4720 Notebook
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
Can i connect my acer aspire 4730z to my television so i can watch dvds
Yes of course.
First of all you will need to identify the available input ports on your TV. An RCA port is generally standard nowadays and it consists of a red, a white and yellow coloured reception ports (the colours may differ between tvs, i.e black instead of red). The red and white are for stero sound and the yellow is for video.
Modern TV systems also have a VGA adapter which is small flat port like the ones on a computer screen. This is usually blue.
A third option is an S-Video port, which is round in shape.
To connect your laptop using the RCA port, you will need an S-Video to RCA converter. You connect the S-Video to the port on your latptop, and through the converter to the RCA yellow port on your TV. For sound you will use another cable that connects to the headphone jack on your laptop and then splits to a white and a red cable to connect to your TV.
If you have VGA port on your TV, then connect the VGA port on your laptop to the VGA port on your TV. No converters needed. For sound you will use the same approach as above.
To use the third option you will need to have an s-video out port on your laptop and you will connect it directly to your TV s-video port. For sound, again you will use the approach as the rca solution.
Then, using your remote control, select the AV mode or depending on your TV select the PC or VGA mode.
Finally, to transfer the video from your laptop to your TV press and hold the Fn key on your laptop's keyboard and then the F7 or F9 key. (It has s small TV icon on it).
That's it!
Regards,
nicolasiac
Apr 08, 2010 | Acer Aspire 4730-4947 Notebook
Link my acer aspire 592o laptop to my panasonic plasma
1. S-Video – This is probably the most commonmethod out there currently because an S-Video cable is cheap as heckand just about every TV under the sun has a S-Video port. You’ll haveto make sure you laptop is equipped with this port. Remember, there aretwo types of S-Video cables: 4-pin and 7-pin. Mostlaptops and PC’s are equipped with a 7-pin port, so if your TV only hasa 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will bebetter off connecting using a VGA cable. It gives much better qualitythan S-Video and as with S-Video, the cable is very cheap. You usuallywon’t find a VGA port on regular TV’s though, so this option is if youhave an HDTV.
3. DVI - DVI stands for Digital Visual Interfacewith “digital” being the key word there. The digital signal will give ahigher quality picture than either S-Video or VGA. Of course, yourcomputer will need to have a DVI connection and your TV will need to bean HDTV. This cord is definitely not cheap, it ranges anywhere from $40to $80.
4. HDMI – Using HDMI will give you the best qualityby far. No computers that I know of yet have HDMI ports, but you canget a DVI to HDMI cable to connect it to your HDTV. HDMI is compatiblewith DVI.
5. Scan Converter Box – This is the last methodthat I could think of and it involves using a scan converter box, whichtakes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel
Jan 26, 2010 | Acer Aspire 5920-6335 Laptop
How to connect my Acer Aspire 5670 outgoing to my TV? I have an SV cable and I believe there is an sv output plug for it. I'm not very technical.
You laptop can connect to any television or display device with S-video input through the S-video/TV-out (NTSC/PAL) port, located on the right side of the laptop (this is the round whitish port located between the two USB ports and the ventilation slots.
The computer has also an external display (VGA) port by which the laptop can be connected to a display device (e.g., external monitor, LCD projector).This is the port on the right side nearest the end of the computer.
Jul 27, 2009 | Acer Aspire 5670 Notebook
What type to cable should I buy to connect laptop to tv
Youre laptop would have to have a video card that has a TV-out port... And for that you would have to run a S-Video cable from the TV-out port of your laptop to the S-Video port on your TV... I assume your TV has a S-Video port?
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
Open Questions:
Get your wife husband back lost love spells caster in city of New York +27832762854 Have you ever been in a failed relationship? Did you often feel like your partner didn't 'get' you? Are you having many obstacles in your life? Is your love life falling apart? Is your life facing financial ruin? Do you need protection from your enemies? If you seek a lost lover, or want a new lover, we can help. We reunite lost lover`s If you are really in love with someone then this is the spell for you. divorce affairs all kind of witchcrafts bring back lost love spells in NHL Eastern Conference bring back lost love spells in Boston Bruins bring back lost love spells in Buffalo Sabres bring back lost love spells in Carolina Hurricanes bring back lost love spells in Columbus Blue Jackets bring back lost love spells in Detroit Red Wings bring back lost love spells in Florida Panthers bring back lost love spells in Montreal Canadiens bring back lost love spells in New Jersey Devils bring back lost love spells in New York Islanders bring back lost love spells in New York Rangers bring back lost love spells in Ottawa Senators bring back lost love spells in Philadelphia Flyers bring back lost love spells in Pittsburgh Penguins bring back lost love spells in Tampa Bay Lightning bring back lost love spells in Toronto Maple Leafs bring back lost love spells in Washington Capitals bring back lost love spells in Western Conference bring back lost love spells in Anaheim Ducks bring back lost love spells in Arizona Coyotes bring back lost love spells in Calgary Flames bring back lost love spells in Colorado Avalanche bring back lost love spells in Chicago Blackhawks bring back lost love spells in Dallas Stars bring back lost love spells in Edmonton Oilers bring back lost love spells in Los Angeles Kings bring back lost love spells in Minnesota Wild bring back lost love spells in Nashville Predators bring back lost love spells in San Jose Sharks bring back lost love spells in St. Louis Blues bring back lost love spells in Vancouver Canucks bring back lost love spells in Vegas Golden Knights bring back lost love spells in Winnipeg Jets bring back lost love spells in NBA Eastern Conference bring back lost love spells in Atlanta Hawks bring back lost love spells in Boston Celtics bring back lost love spells in Brooklyn Nets bring back lost love spells in Charlotte Hornets bring back lost love spells in Chicago Bulls bring back lost love spells in Cleveland Cavaliers bring back lost love spells in Detroit Pistons bring back lost love spells in Indiana Pacers bring back lost love spells in Miami Heat bring back lost love spells in Milwaukee Bucks bring back lost love spells in New York Knicks bring back lost love spells in Orlando Magic bring back lost love spells in Philadelphia 76ers bring back lost love spells in Toronto Raptors bring back lost love spells in Washington Wizards bring back lost love spells in Western Conference bring back lost love spells in Dallas Mavericks bring back lost love spells in Denver Nuggets bring back lost love spells in Golden State Warriors bring back lost love spells in Houston Rockets bring back lost love spells in Los Angeles Clippers bring back lost love spells in Los Angeles Lakers bring back lost love spells in Memphis Grizzlies bring back lost love spells in Minnesota Timberwolves bring back lost love spells in New Orleans Pelicans bring back lost love spells in Oklahoma City Thunder bring back lost love spells in Phoenix Suns bring back lost love spells in Portland Trail Blazers bring back lost love spells in Sacramento Kings bring back lost love spells in San Antonio Spurs bring back lost love spells in Utah Jazz bring back lost love spells in NCCA bring back lost love spells in Air Force Falcons bring back lost love spells in Alabama Crimson Tide bring back lost love spells in Arizona State Sun Devils bring back lost love spells in Arizona Wildcats bring back lost love spells in Arkansas Razorbacks bring back lost love spells in Army West Point Black Knights bring back lost love spells in Auburn Tigers bring back lost love spells in Baylor Bears bring back lost love spells in Boston College Eagles bring back lost love spells in BYU Cougars bring back lost love spells in California Golden Bears bring back lost love spells in Clemson Tigers bring back lost love spells in Colorado Buffaloes bring back lost love spells in Florida Gators bring back lost love spells in Florida State Seminoles bring back lost love spells in Fresno State Bulldogs bring back lost love spells in Georgia Bulldogs bring back lost love spells in Georgia Tech Yellow Jackets bring back lost love spells in Houston Cougars bring back lost love spells in Illinois Fighting Illini bring back lost love spells in Indiana Hoosiers bring back lost love spells in Iowa Hawkeyes bring back lost love spells in Iowa State Cyclones bring back lost love spells in Kansas Jayhawks bring back lost love spells in Kansas State Wildcats bring back lost love spells in Kentucky Wildcats bring back lost love spells in Louisville Cardinals bring back lost love spells in LSU Tigers bring back lost love spells in Maryland Terrapins bring back lost love spells in Miami Hurricanes bring back lost love spells in Michigan State Spartans bring back lost love spells in Michigan Wolverines bring back lost love spells in Minnesota Golden Gophers bring back lost love spells in Mississippi Rebels bring back lost love spells in Mississippi State Bulldogs bring back lost love spells in Missouri Tigers bring back lost love spells in Navy Midshipmen bring back lost love spells in Nebraska Cornhuskers bring back lost love spells in North Carolina State Wolfpack bring back lost love spells in North Carolina Tar Heels bring back lost love spells in Northwestern Wildcats bring back lost love spells in Notre Dame Fighting Irish bring back lost love spells in Ohio State Buckeyes bring back lost love spells in Oklahoma Sooners bring back lost love spells in Oklahoma State Cowboys bring back lost love spells in Oregon Ducks bring back lost love spells in Oregon State Beavers bring back lost love spells in Penn State Nittany Lions bring back lost love spells in Pittsburgh Panthers bring back lost love spells in Rutgers Scarlet Knights bring back lost love spells in South Carolina Gamecocks bring back lost love spells in South Florida Bulls bring back lost love spells in Southern Methodist SMU Mustangs bring back lost love spells in Stanford Cardinal bring back lost love spells in TCU Horned Frogs bring back lost love spells in Tennessee Volunteers bring back lost love spells in Texas A&M Aggies bring back lost love spells in Texas Longhorns bring back lost love spells in Texas Tech Red Raiders bring back lost love spells in UCLA Bruins bring back lost love spells in USC Trojans bring back lost love spells in Utah Utes bring back lost love spells in Vanderbilt Commodores bring back lost love spells in Virginia Tech Hokies bring back lost love spells in Washington Huskies bring back lost love spells in Washington State Cougars bring back lost love spells in West Virginia bring back lost love spells in NFL AFC bring back lost love spells in Baltimore Ravens bring back lost love spells in Buffalo Bills bring back lost love spells in Cincinnati Bengals bring back lost love spells in Cleveland Browns bring back lost love spells in Denver Broncos bring back lost love spells in Houston Texans bring back lost love spells in Indianapolis Colts bring back lost love spells in Jacksonville Jaguars bring back lost love spells in Kansas City Chiefs bring back lost love spells in Los Angeles Chargers bring back lost love spells in Miami Dolphins bring back lost love spells in New England Patriots bring back lost love spells in New York Jets bring back lost love spells in Oakland Raiders bring back lost love spells in Pittsburgh Steelers bring back lost love spells in Tennessee Titans bring back lost love spells in Super Bowl LII bring back lost love spells in NFC bring back lost love spells in Arizona Cardinals bring back lost love spells in Atlanta Falcons bring back lost love spells in Carolina Panthers bring back lost love spells in Chicago Bears bring back lost love spells in Dallas Cowboys bring back lost love spells in Detroit Lions bring back lost love spells in Green Bay Packers bring back lost love spells in Los Angeles Rams bring back lost love spells in Minnesota Vikings bring back lost love spells in New Orleans Saints bring back lost love spells in New York Giants bring back lost love spells in Philadelphia Eagles bring back lost love spells in San Francisco 49ers bring back lost love spells in Seattle Seahawks bring back lost love spells in Tampa Bay Buccaneers bring back lost love spells in Washington Redskins bring back lost love spells in MLB bring back lost love spells in AMERICAN LEAGUE EAST bring back lost love spells in Baltimore Orioles bring back lost love spells in Boston Red Sox bring back lost love spells in New York Yankees bring back lost love spells in Tampa Bay Rays bring back lost love spells in Toronto Blue Jays bring back lost love spells in AMERICAN LEAGUE CENTRAL bring back lost love spells in Chicago White Sox bring back lost love spells in Cleveland Indians bring back lost love spells in Detroit Tigers bring back lost love spells in Minnesota Twins bring back lost love spells in Kansas City Royals bring back lost love spells in AMERICAN LEAGUE WEST bring back lost love spells in Houston Astros bring back lost love spells in Los Angeles Angels bring back lost love spells in Oakland Athletics bring back lost love spells in Seattle Mariners bring back lost love spells in Texas Rangers bring back lost love spells in NATIONAL LEAGUE EAST bring back lost love spells in Atlanta Braves bring back lost love spells in Miami Marlins bring back lost love spells in New York Mets bring back lost love spells in Philadelphia Phillies bring back lost love spells in Washington Nationals bring back lost love spells in NATIONAL LEAGUE CENTRAL bring back lost love spells in Chicago Cubs bring back lost love spells in Cincinnati Reds bring back lost love spells in Milwaukee Brewers bring back lost love spells in Pittsburgh Pirates bring back lost love spells in St. Louis Cardinals bring back lost love spells in NATIONAL LEAGUE WEST bring back lost love spells in Arizona Diamondbacks bring back lost love spells in Colorado Rockies bring back lost love spells in Los Angeles Dodgers bring back lost love spells in San Diego Padres bring back lost love spells in San Francisco Giants
Aug 20, 2018 | Sun Computers & Internet
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
