Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
How can i patch a hole on fuel tank
I have a ryobi trimmerplus weedwacker and it has a one eights hole in fuel tank how can i patch it.
  • 405 Answers
Put an o-ring on a screw a little bigger than the hole and screw it down till the oring is compressed. This has worked for me, hope it helps you
Posted on Dec 18, 2008
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
TrimmerPlus 720r Manual
Mine would start and run on the primer gas then die. Replaced the plugged fuel screen under the flapper valves on the single large screw cover of the carb. Runs well now
Aug 30, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a Husqvarna trimmer model # 128LD.I want to get a tiller attachment.Can you give me the model I need for my model?
If you have the 128LD from Lowe's, Tractor Supply or Sears you can use TrimmerPlus attachments, any MTD manufactured attachments should work.
http://www.trimmerplus.com
May 26, 2010 | Husqvarna Garden
I want to change the fuel filter on my weedwacker
The fuel filter is in the fuel tank. Before removing make a sketch of where the fuel lines connect to. Empty the tank and use a flash light and look inside the fuel tank to see which line has the filter on it. There's a retainer on the fuel line up against the fuel tank on the outside. Use a small screwdriver to remove this retainer. It looks like a washer. Remove the fuel line from the carburetor and using needle nose pliers pull on the old filter and remove it from the filler hold with the fuel line still connected. You should use a new fuel line the same diameter as the old one. From the outside feed the fuel line through the hole. It will be tight. Push it through until you can get a hold of it through the filler hold. Put the filter on then pull the fuel line back. Pull until the filter is up against the fuel tank. Put the retainer on the line and while pulling the fuel line tight press the retainer up against the tank. Attach the end of the fuel line back on the carb.
May 05, 2010 | Garden
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Got a homelite ut 15039a (weedwacker with blade st 185)
You have the rong fuel tank for that model.Thats the return pipe its comming from so you can drill a hole if youwant but make sure its sealed properly.
Jul 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jul 03, 2009 | Ryobi Garden
Gas line installation on Weedwacker 18" 24cc
The hole in the tank is slightly smaller than the fuel line, else it would leak. So.. you can't push it in, you have to pull it in. I use a label tag wire (about 10" long), stick it through the hole and out the fuel cap hole. Snip the fuel line at an angle on the end, punch a hole in it then stick the wire through the line and twist it. Now you can pull the line through the hole.
Jun 15, 2009 | Homelite Mighty Lite Lawn Trimmer
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Gas oil mixture
Hello slabieniec:
The Newer 2 Cycle Trimmers use a 50:1 Ratio (OEM Suggested Ratio). I Use a 40:1 Ratio in Most of my Equipment, Except for Chainsaws and Hole Drillers/Augers. For the Chainsaws I Use a 32:1 Ratio and the Hole Digger/Auger Uses a 25:1 Ratio.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
