Question about Olympus DS-4000 Digital Voice Recorder
Lock/read only card message
When I turn on the recorded a lock and read only card message appear on the screen. the recorded won't do anything. Please help
    President:
  • 919 Answers
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Posted on Dec 19, 2008
Sony RDR-HX525 won't play some DVDs recorded elsewhere. A lock symbol appears on title list. Plays OK on other machines.
that lock icon is childlock to remove that please read your manual on how to unlock..if you don't have manual please let me know..
Thank you for using fixya..
Jan 07, 2012 | Televison & Video
My camera says my memory card is locked but the button on the side is not locked how do i retrieve my pictures i have a canon powershot a480
Issue: [Memory card locked] message appears on the screen.
Solution: Change the memory card lock switch to the normal setting
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Please remove the card from the camera and ensure that the switch is not in the locked position. sdcardlocked.jpg
sdcardunlocked.jpg ---
You should be able to retrieve photos, but not writing or erasing if the switch is switched to write protect.
If it's not functioning correctly, the camera may need service at Canonusa.com.
Jun 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
My SGH-T629 came from the U.S. how can i make it capitable with the sim card in the phillipines
A. Turn on phone with full battery and non-T-Mobile SIM in place.
Allow phone to completely boot up to Wrong SIM screen. B. Enter from Wrong SIM Screen *#7465625# to confirm lock status C. Scroll through Interrogate Screen 1. Network lock - Active (this is the one you'll be deactivating)
2. Subset lock - inactive
3. SP lock - inactive
4. CP lock - inactive
5. SIM Card lock - inactive
6. Activa lock - inactive
7. Auto network lock - inactive
8. Auto subset lock - inactive
9. Auto SP lock - inactive
10. Auto CP lock - inactive
11. Auto SIM Card lock - inactive
12. Phone lock - inactive D. Push "C" button under navigation button to clear Interrogate screen back to Wrong SIM
screen E. From the Wrong SIM screen enter the following: *7465625*638*00000000*00000000# Those are two series of eight zeros. The phone will not show the zeros but will show dashes in their place. Phone may make a small tone and at the bottom of the screen it will read "Network Personalized" or perhaps "Network Already Personalized" F. Now input the following from whatever screen shows up: #7465625*638*00000000# (again this is a series of eight zeros) Phone may make small tone and will read "Network Lock Deactivated" G. Turn off phone
H. Re-start the handset and allow it to reboot.
J. Enter from Standby Screen *#7465625# to confirm lock removal status K. Scroll through Interrogate Screen 1. Network lock - inactive (note that this lock is now inactive)
That's it. Your phone is ready to accept SIM cards from just about any GSM mobile telephone service provider in the world. If you received a "wrong password" message you will need to insert a working SIM and reset the password to the default 8 zeroes "00000000". After that you may try this process again and it should work.
Dec 02, 2008 | Samsung SGH-t629 Cellular Phone
Code region
1 Use the remote
2 Press HOME
3 Move to SETUP
2 Scroll down to LOCK (no need to enter LOCK options)
3 Press '0' seven times
A message that confirms that the player is region free will appear on the screen
hope it helps!
Nov 16, 2008 | LG RH266 Recorder
DS-400 DIGITAL VOICE RECORDER
went on the "menu" option and formated the disk. I first downloaded the files I needed to my computer. Took off the "lock" option.
Jun 25, 2008 | Olympus DM-20 Digital Voice Recorder
Locked file ?
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Had same problem. Found online handbook for DS-4000 and page 37 pointed way.
Press menu button on the handset.Go to sub menu. Page 37 of online handbook suggests you can lock and unlock from this but I used the format icon on the submenu to reformat the card. Seems to be working fine now.
Feb 14, 2008 | Olympus DS-4000 Digital Voice Recorder
In card position
check the SD card and see if the little tab on the side of it is slid to the position that says "lock" If you cant see the words, try just switching the tab to the other side. Since SD means Secure Digital, these cards wont do anything if the lock tab is not in the right position.
Feb 08, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Olympus DS-4000 Digital Voice Recorder Logo
2,687 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
