Question about Ruud UBHC Air Conditioner
Ruud heater will not light consistently
I have a ruud heater and at times the ignitor doesnt come on, which means the gas doesnt come on and the furnace doesnt light. when the thermostat turns the blower fan on it continues to run and doesnt shut off. this problem was intermittent but seems to be happening all the time now. whats really strange about it is that if i go to the unit and turn off the power switch at the unit and turn it back on, the ignitor lights and the furance kicks on and everything is ok until the next time.
I am having the same exact problem. The furnace is 6 yrs old. It is a RUUD Acheiver 90Plus.
Posted on Mar 03, 2013
If your house was built "back in the day" when there were only 2 prong plugs you will experience grounding problems.actually...lack of ground problems.flame sensor good, at times, and other times nothing.ground your furnace at control box to the nearest water pipe using 14 awg wire.
Posted on Jan 09, 2009
  • 24 Answers
Your furnace is going into a lockout condition, cycling the power resets the circuit board and it starts over. I will need to know approximate age and model of your furnace, it sounds like you have need to clean the flame sensor rod. However i need to know what i am working with.
Posted on Dec 18, 2008
I have a 20 year old Ruud gas water heater with a power vent. The model is PVP 40-1. Sometimes it will not heat water. The power vent is running but neither the ignitor or the burner is. If I turn off the...
My guess is the ignitor needs replacing (old and has built up too much internal resistance). Even though it still works at times, I would suspect it first, even if it glows during an ignition cycle.
Dec 07, 2014 | Water Water Heaters
What does fault ing control mean on a LRZE pool heater
means it tried to fire 3 times and didnt light ignition failure make sure gas valve is on then see if ignitor is glowing if not need ignitor
May 18, 2014 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
Hayward H400 error code IF (Ignition Failure)
yes, make sure you order the correct part, youll need the model number and serial number. the ignitor has 2 wires wrapped with white fibers, usually 2 screws to remove it, and theres only one way to plug it back in. NOTE: Ignition failure does not always mean the ignitor needs replaced. make sure your ignitor doesnt turn on and glow when you start the heater. if it does, youll want to clean out the gas orifices.
Apr 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
I have a Ruud Silhouette 2 gas furnace. The draft fan starts, ignitor then glows, main burners light and go out after a few seconds at the same time the ignitor goes off. I have replaced the flame sensor...
I had the same problum with my heater to no end. I thought it was the th-sat . still don't know if it was . one of the sencers I was feeling, and the disc snapped in and the heater ran but on heat. turn off power and unplug the power cord and removed the sencer and taped it until it pop back out and when it did I resemble back in place.repluged all back up. turn the heater back on and the flame stayed on . LET THEIR BE HEAT. I played with it for 4 hrs.I don't know if this was the problum .will have a teck look at it to be safe.
Dec 27, 2010 | Ruud UBHC Air Conditioner
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heater exhaust blower comes on ignitor lights but it doesn't seem to get gas everything works but no flame and blower won't kick on the unit is brand new and was working this morning then stopped
This furnace should have a trobleshooting diagnostic led flashing light. Each blink (for example 3 blinks means open limit switch) has a particlur meaning. On the bottom panel has an explaination on what the blinks mean. But in the meantime check 24v at the gas right as the ignitors light. If you have 24v and the gas valve doesnt let the gas thru then the gas valve might be defective. I usually put 24v dircetly to the gas valve for 2-3 seconds to see if gas will come out. It is loud enogh to hear as well as smell. If you dont have 24v as the ignitor tries to light then check the air pressure switch. Also follow the wire off the gas valve. One is to ground. Make sure the gas valve is grounded. Follow not the grounded wire but the other one. Find out where the 24v power stops.
Mar 24, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Heater lights for about 5 sec and then goes out
One flash on a Ruud furnace indicates failure to ignite. There is a viewing port on the furnace where you can watch the flame. If the ignitor is igniting the burner and then 2 or 3 seconds later, the flame goes out; you most likely have a flame sensor that is dirty or not working. Check to make sure you are getting gas. Check the connections of all wires to the control board. If the sensor is not part of the ignitor, see if you can get to it to clean it with a small wire brush. Make sure there is a good ground connection between the board and furnace frame. If the flame is not traveling all the way to the flame sensor, clean your burners. If the flame burns inside the burners, you may have weak gas pressure. Good Luck.
Sep 29, 2007 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
554 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
