Question about Toaster Ovens
Ultrex Convection Commercial Oven 08396 will not turn on
Oven is maybe 2 years old, slightly used. It has a touch on-off button to add minutes to turn oven on and will no longer turn on. I do not have service manual. Is there a fuse that needs replaceing?
SOURCE: manual for aroma aeromatic convection oven
http://www.aroma-housewares.com/manuals/AST-900E_InstructionManual.pdf
Posted on May 20, 2010
  • 10 Answers
SOURCE: Farberware Convection Oven T490c does not turn on.
It is usually one of two items that could cause this problem. You need to take the outer shell off. Lots of screws. Pull the "brain board" from the right, front of the oven. There is a relay housing. This 30 amp. relay is made by Omron. Look at the connector pins on the back side of the relay, especially the white wire that goes to the distribution block then on to the heating coil. I find that the soldered pins on the pc board next to the relay often get so hot that they 'shed' the solder. If so, simply clean well and re-solder. The relay itself can also go bad. Unfortunately, I haven't been able to obtain replacements. What I did on one oven was to buy a 30 amp, open frame relay (~$20). Mount it on the chassis near the fan. Remove the Omron relay and simply run the appropriate wires to the open frame relay. That works very well.
Posted on Dec 06, 2008
  • 30 Answers
SOURCE: CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Posted on Dec 30, 2008
crappy_focus
  • 51 Answers
SOURCE: Need manual for Euro-Pro professional Model K5345B combo oven
here is a link to allow you to download the manual. go to this link and choose get manual.
hope that helps:)
Posted on Feb 11, 2009
cactus bob
  • 267 Answers
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Posted on Apr 02, 2009
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
Received a B&D Convection,Toaster,Rotissere oven but did not get a operator's manual and am not familiar with the convection operation. Can I get a manual? I believe this oven is about 2 years old but...
Try the following site: http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4 . Then scroll down or use the Find feature of your browser (under Edit). You want the manual for the TRO200 and TRO300 series toaster ovens for the TRO355. If you have a different model which seems likely (since the TRO300 series aren't convection models), scroll through the list for one that matches the TRO and either the whole model number or the first digit or two. (Usually the model number is on the back of the toaster oven on a plaque with the serial number.)
I hope this helps.
Dec 17, 2010 | Black & Decker TRO355 Toast-R-Oven 1550...
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Our CTO650 toaster oven dosn't toast, but the oven works fine. How do I get into it, and can this problem be fixed?
I called the 800 number on the instructions (800-231-9786),. I suffered through a confusing phone tree AND a 10 minute wait on hold. I was told that my 3 year old toaster oven is "fairly old" and that parts are no longer made for it.
Very frustrating. I expect a toaster over 1) to work and 2) to have parts available for 10 years after I purchase it. The ideas of a toaster oven as a "consumable" has terrible implications for our environment.
Feb 01, 2010 | Black & Decker CTO650 1500 Watts Toaster...
Can you cook a stuffed turkey in the roater oven
Yes, similar timewise to a regular oven. But it depends on the size of the turkey, if stuffed you definitely want to check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound unstuffed turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. It adds about 1-2 minutes per turkey pound if stuffed.
All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 21, 2009 | Hamilton Beach Toaster Oven with...
Can you change the default settings
hi friend,
  1. Touch Control Setup pad.
  2. Touch number 1 pad.
  3. Touch number 2 pad.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | DeLonghi DO400 Toaster Oven with...
Oven does not turn on
These ovens have a timer switch that lasts just about a year. Mine did the same thing and you cannot find the timer switch anywhere in the USA. The switch is likely a DKJ/1-60. There is a switch made by Delonghi that will work. The part # is 05XDE5218104600. You can get one at "The Gourmet Depot" website for $10 + shipping.
Jan 23, 2008 | Black & Decker CTO6300 Toaster Oven with...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Toaster Ovens Logo
403 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
