Question about Canon imageCLASS D761 Copier
Paper cannot be fed through automatically
The automatic feeder is not grabbing the paper to put through the copier. What can be done to fix this problem.
    President:
  • Canon Master
  • 990 Answers
Dear sir; there have a cover on the auto feeder, open the cover, you going to see few rollers ,clean all rollers with rubber rejuvenator or rubbing alcohol it will take care the problem otherwise you have to replace document pick up roller, please let me know how does it work out, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 18, 2008
When making photocopies, the automatic top paper feeder is grabbing more than one page at a time. How do we fix it?
Clean all the rollers in the ADF with a damp lint free cloth. Depending on wear, they may need to be changed, but try cleaning first. Where the paper stack rests there will be either a pad or roller, make sure it is clean too.
Dec 08, 2014 | Copystar CS-2550 All-In-One Printer
My Automatic Document Feeder for my HP Photosmart 7520 won't work
Does it grab paper at all? Does the paper jam in the doc feeder? does it scan when place on the glass?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 16, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
Epson 810 automatic feeder won't feed
do you let the paper get pulled by it'self? Maybe try to push it and maybe it will grab it better to pull through...if not try a shop to fix or buy new one.
Sep 09, 2012 | Epson Artisan 810 AllInOne InkJet Printer
Paper feeder grabs several pieces of paper at once
The spot in which the paper is fed into could have a fence/blocker. Use wood or a little hunk of aluminum to only allow 1 sheet. You could get fandy and use a rod that could also be mounted on the font.Be crea8tive and good luck.
Jul 21, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Straight thin line prints on copies from feeder
When the paper is fed through Automatic Document Feeder (ADF) it is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying! For example see the below picture: -
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 18, 2011 | HP OfficeJet J4580 All-In-One InkJet...
What does an adf jam mean? what do i have to do to fix that? dell photo 964
The ADF is the "automatic document feeder". It's at the top of the printer. It's where you place multiple sheets of paper on a tray to get fed into the copying part of the printer.
There is either a sheet of paper jammed in there or a piece of a paper stuck in there.
May 26, 2011 | Office Equipment & Supplies
My HP officejet Pro L7680 cannot scan anymore. It keeps saying: "Reload the Document & restart the job. And when scaning through PC then give an error msg: "The automatic Document deeder is...
does the feeder try to fed the paper? if you hear not working and not fed the paper then clean with alcohol with hard paper the roller .
if not fix did you hear noises? maybe the gears.
hope i help
Dec 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
Fax
If you use the automatic document feeder to make a copy, do you see the same line? If so, the scanner glass needs to be cleaned. Not the entire glass, just the small area to the left side that scans paper as it is fed through the automatic sheet feeder. Use a soft cloth lightly dampened with plain water to remove any material on this area of the scanner glass.
Jun 06, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP PSC 1510 printer malfunction
Open the rear cover and clean the roller with clean water. Worked for me.
Mar 05, 2008 | HP PSC 1510 All-In-One InkJet Printer
Help please. can't print: paper light flashing even though there is paper in printer
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't,  and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that  is slightly out of reach.
Mar 15, 2007 | Brother HL 5140 Laser Printer
Canon imageCLASS D761 Copier Logo
98 people viewed this question
old marine
old marine
