Question about Panasonic PT-51G44 51" Rear Projection Television
Convergence issue i actually have a PT51G63 but cannot find it under the models... i bought it used about a week ago and it worked fine but had isues with really dark objects ... this morning i turned it on and the red is about an inch to the left of everything else... there is a mini-fridge to the left of the tv and i was wondering if that may have messed it up... i was also up for a late night of extreme awesome gaming on it last night... the thing is under convergence i try to change it but i no longer have the original remote ... i can get into the convergence menu using the buttons on the tv but the navi buttons act like normal volume/channel buttons while its open ( so instead of changing the convergence the volume just goes up or down or the channel changes ) what do i do !! ( besides buy a new tv please )
  • Anonymous Apr 29, 2009
    I have the same issue - although the solution that was posted got me excited - it did not reset the convergence for whatever reason…Any other options?
    President:
  • 1,284 Answers
You can go back to factory settings by pressing and holding the ACTION and POWER buttons on the TV while it is on. A CHK screen will appear and when it does release the buttons and then power the set off then on again. This had reset all settings back to factory conditions. You will have to reprogram any channels into memory after this.
Posted on Mar 29, 2007
My Goodman AC is model WMC24-1. Two years ago it quit responding to the remote control. We bought a replacement B1100108. That worked...for awhile.
Make sure the sun is not directly on the unit and nothing is blocking the unit. for once in awhile if the sun hits it just right when you try to use the remote it will not work.that seems to me what is wrong for spring time the sun is real low
Sep 03, 2018 | Heating & Cooling
I bought a bissel quicksteamer powerbrush multisurface 2 weeks ago used it once. Now it will not **** up the water it sprays fine but won't **** up
if you bought ot new.its under warantry, take it back were you bought it, you are covered under the sale of goods act the, shop has to fix the problem
Aug 16, 2011 | Bissell Vacuums
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Sony KP-65WS500 Rear Projection TV About a week ago the left side of the screen started to a slight blue halo over faces, hands, and some of the white letters were light yellow. I adjusted the convergence...
Thats a convergence failure issue. The Sony Type 1 convergence repair kit available from www.tvrepairworld.com is the kit your model uses. The kit contains the parts and the CD with instructions.
Dec 20, 2009 | Sony KP-65WS500 65" Rear Projection...
My mitsubishi 60" screen turns on but has red-like waves. Is sound in background, but it shuts down, too. Anybody know what it might be. I just bought and moved it to my house two weeks ago. Worked fine...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Hi!! This is in regards to my Panasonic pt-47wx53g
There is a convergence repair kit available for your model which contains both Convergence ICs and the six feed resistors the kit also comes with free step by step with detailed pictures that explain and show how to do the repair. Heres the link to the Kit for the PT47WX53G panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 25, 2009 | Cameras
Green double image
you need to replace both convergence ICs they are both STK392-110 and you can get replacement ICs at the following link and they provide free step by step instructions with pictures so you can do the job yourself. Heres the link.
Jun 30, 2008 | JVC AV-65WP74 Rear Projection Television
No more sound on Toshiba Qosmio G30-155
Take it back. Should still be under warranty.
Apr 13, 2008 | Computers & Internet
Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen...
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
Mar 24, 2008 | Televison & Video
Convergence
You need to go to http://www.partstore.com, enter your model number,look up under that model number STK #(@-560. Order Two of the part number 874901908. These also need heat sink grease in the back of these ICs when they are replaced. If you know how to solder, then good luck, and please be carefull!.. Please do not forget to rate this thread.
Nov 26, 2006 | Sony KP-46WT500 46" Rear Projection...
Panasonic PT-51G44 51" Rear Projection Television Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
