Question about Whirlpool LGR3624JQ Gas Dryer
Gas dryer not heating up
Whirlpool model lgr4634eq3. I have replaced the coils on the gas module and replaced the ignitor and still get nothing. Ignitor does not glow when dryer is running. Thanks
  • 2 more comments
  • Mike Flaherty Mar 30, 2007
    Iunplugged the wires and checked the fuse with my meter and got no reading at all. I assume that it it needs to be repalced. Thanks
  • Mike Flaherty Mar 31, 2007
    I replaced the fuse and it works like new. Thanks for the help, much appreciated.
  • ham442 Apr 10, 2008
    Changed hot surface ignitor and burner lite two or three times and then not all the time. Hot surface ignitor comes on and then goes back off.
  • Anonymous Mar 15, 2014
    "gas dryer no heat troubleshooting." STEP BY STEP INSTRUCTIONS HOW TO REPLACE IGNITOR
    President:
  • 878 Answers
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
Posted on Mar 29, 2007
  • Ron Marek
    Ron Marek Mar 29, 2007
    If the thermal is blown on a gas dryer, no power to ignitor
Dear sir
hi
would you please let me know more about the system of dryer.
sincerely
j.alavi
Posted on Feb 24, 2008
Model # LGR4634EQ3 is turning but it is not getting hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Whirlpool Dryers
Whirlpool lgr4634eq3 gas dryer-runs on low heat or heat fails to work-sometimes. Timer is new; plenty of gas, the ignition element obviously works
i would check your gas valve coils
they are probably weaking or at least your hold is
but i would replace both
they sit right on top of your gas regulator behind the ignitor
two littly tube like things
Oct 09, 2009 | Whirlpool Dryers
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Jul 24, 2009 | Whirlpool Dryers
Gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 12, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer flame goes on and then off
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 05, 2009 | Dryers
Whirlpool dryer (no heat)
does the ignitor light up if it does check continuity on the thermo fuse (the little white one) if ok replace coils
Feb 19, 2009 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool LGR4634EQ3 not heating
most likely your coil set is bad. is it turns on once, but then doesn't ignite again, your coil set is overheating and not working. it will need to be replaced. Joe
Dec 02, 2008 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
3,496 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
