Idling roller HP sensor remains on or off The idling roller HP sensor does not change status within 4.0 seconds after the idling roller motor on signal is generated.
41 is cam sensor code. are you sure the magnet is still in the cam gear? use only quality parts. if the magnet is missing, you need to replace the timing gears/chain.
The code 41 is indicating an EST control issue. I would check you connection at the ignition module, make sure the connector is locked securely and there is no corrosion in the connector or terminal pins on the ignition module.
The EST is your electronic spark timing control, the module is not switching over to ECMcontrolled timing. The ECM sets the code when it can not take over control of the timing. If the connections look good, you likely have an ignition module that has gone bad.
Good luck and let me know.
Regards,
Here is the explanation and solution for the error code 41:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
