Question about HP Compaq nx5000 Notebook
Problem using my nx5000 laptop. I am unable to start it. When i try to start my computer only the led flickers and it attempts to boot, but nothing happes excepts for the led flickering.... please help.
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
HP 6735s laptop with AMD Turion X2, screen remain dark...
Try locating your memory sticks under unit, try taking them out and resitting them, try also resitting your hard drive.
if this does not work let us know
Jan 04, 2010 | HP Compaq 6735s Notebook
Hp Compaq nx5000 Laptop selft boot / restart when plueged
You need to replace the power supply, don't continue to use it for it would cause damage to your computer.
Nov 02, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Can't log into computer though it powers on
Restart the computer..
tap f8 repeatedly while its first booting up
first try, use last known good configuration..
if that wont let you type.. then try, start in safe mode..
If that doesnt work, then you may need to flash the bios..
Oct 30, 2009 | Acer Aspire 5500 5570-2609 Laptop
Will not show anything after log in
Just before the Windows logo screen appears press F8 and chose "Last Known Good Configuration", see what happens it might fix any driver related issue. If not you can try "safe mode" from the F8 menu and see does that boot.
May 17, 2009 | HP Compaq nx5000 Notebook
Acer Ferrari 3200 won't boot
Try different memory just to be sure its not that and if still no boot then its the motherboard.
Feb 10, 2009 | Dell Inspiron 2200 Notebook
HP Compac NX5000 wont load XP Home on new hard drive
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty.
Try cleaning the disc and begin again.
Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave.
And copy your WinXp cd onto a partition on your laptop HD.
Then using a Win98Se floppy boot disc you can access the winXP and install from there.
Nov 12, 2008 | HP Compaq nx5000 Notebook
Compaq nx5000 startup trouble
Atleast you need a dummy battery on it,put the battery on it and check , one more way is remove the ram and fix
Mar 13, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000 Notebook Logo
270 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
