Question about Panasonic PT-47WX49 47" Rear Projection Television
Ghost images on tv
I turned on my set today and everything seems to be double vision. Even when I play a DVD. any ideas
    President:
  • 1,284 Answers
Bod convergence IC's. Try doing a reset of the TV first by pressing and holding the ACTION and POWER buttons while the set is on. A CHK screen with diagnosis will come up in about 5 seconds. Once that happens release the buttons and shut the set off and then turn it back on. If problem still is there then convergence circuit problems need to be fixed.
Posted on Mar 29, 2007
Sony bravia 52 kdl xbr ghosting
Michael, does the ghosting go away of you tap the set? Or if you turn off the set and let it cool off and turn it back on, is the ghosting still here? One of the most common causes of ghosting or double image problem is due to a defective LCD panel tab. Sony's are known for this problem. I would recommend getting a diagnoses done on the set to be sure. If it turns out to be a LCD tab problem, the only true fix is to replace the panel.
Nov 24, 2012 | Sony BRAVIA Televison & Video
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Hello
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Nov 22, 2010 | ZenithZ2541S 25" TV
Double vision sony tv
Hello, This is the "kiss of death" for an projection set. It is failure of the convergence electronics. And, it is not something you can do by yourself unless you have technical skills and know how to use a soldering iron at the advanced level.
May 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Ghost vision
wel if the ghost vision is still there try and set the brightness and contrast from your xbox 360 console
May 20, 2009 | Microsoft Premium System for Xbox 360
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
53fdx20b double vision?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
DVD not playing in colour
Have you used this DVD before in this player? Does it work in another player. Im thinking if it is new maybe its in the wrong format to use with your TV set.
Oct 08, 2006 | Yahoo Diamond Vision DVDC803-04 DVD Player
Panasonic PT-47WX49 47" Rear Projection Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
