Question about Harman Kardon AVR 230 6.1 Channels Receiver
3-28-07 After coming home from a trip back east, I turned the AVR 230 on and no sound would out of any of the six speakers. The system has worked great for three years so I thought that maybe the little wife had been experimenting with the remotes so I made sure everything was as it should be. Still, no sound. I tried resetting the processer by holding the mode button in for three seconds but no luck. Please Help. Thanks, Moondawg
  • 2 more comments
  • Anonymous Nov 13, 2007
    I only get sound when I turn off surround mode. It seem like the optical inputs are not working at all.
  • sajiv Jan 12, 2008
    I have the same problem, we were out for two months and it worked for the very first of day of return, played 3 dvds. The very next day it stopped working, while playing dvd.
    The power is up, remote works great, tried the input sources coaxial,optical,FM. No sound. Speakers worked great when hooked directly to dvd player.
  • slfree Mar 23, 2008
    Hooked up my Harman Kardon AVR 230 receiver to my new Hitachi Plasma..no sound.. worked fine when hooked up to my old tv. Flashes unlock but have went through everything in the manual to do.
  • sharkystuff Nov 15, 2008
    I've got the same problem... Any solutions yet?
5 Suggested Answers
SOURCE:
robotek
  • 1512 Answers
SOURCE: How to I reset my
Hi odysy
I got this from the manual page 43.
Resetting the Remote Memory
As you add components to your home-theater
system, occasionally you may wish to totally
reprogram the remote control without the confusion
of any commands, macros or ”Punch-
Through“ programming that you may have done.
To do this, it is possible to reset the remote to the
original factory defaults and command codes by
following these steps. Note, however, that once
the remote is reset, all commands or codes that
you have entered will be erased and will need to
be re-entered:
1. Press any of the Input Selector buttons 4
and the ”O“ button Hat the same time until
the Program/SPL Indicator 2begins to flash
amber.
2. Press the ”3“ button Hthree times.
3. The red LED under the Input Selector4
will go out and the Program/SPL Indicator
2will stop flashing and turn green.
4. The Program/SPL Indicator 2will remain
green until the remote is reset. Note that this may
take a while, depending on how many commands
are in the memory and need to be erased.
5. When the Program/SPL Indicator 2goes
out, the remote has been reset to the factory settings.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 29, 2008
SOURCE: goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Posted on May 31, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
  • 308 Answers
SOURCE: AVR amber light will not return to blue after
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Posted on Mar 04, 2010
Harman Kardon AVR 25II no sound from left channel
Sounds like the left channel has blown in your AVR 25II. If it was a faulty headphone jack it simply wouldn't send an output signal to the speakers.
Oct 01, 2018 | Harman Kardon Audio Players & Recorders
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
Cripes, been working great for several years, (My Harman Kardon AVR 335) but my coffee maker shorted out and trip the circuit breaker in my house that must also be in line with living room. Of course I...
Sounds like it's in protection mode, receivers do this so avoid circuit damage. It's usually only when speaker connections are shorted, but here it appears it has a surge protection of some kind. A local hifi shop will usually be able to reset such problems.
Jan 05, 2010 | Harman Kardon AVR 335 Receiver
My center speaker does not work with harman kardon avr 40
perform a test from the menu for speaker output.Your op manual will gude you thru this
Oct 07, 2009 | Harman Kardon AVR 40
Harman Kardon AVR 245 Receiver PROTECT Error Message/Shutting Down All Equipment
could be your receiver only, it has tripped due to discrepancy on the output stage of your amp. that cracking sound in one of your speakers could have caused the trouble. it is possibly shorted. but in your case it could have damaged already the amp that;s why it would not turn on. normally it will first trip, turn on then turns off. but to stay off and not to turn on again is major problem of the amp. or maybe it emanated from miscabling, probably the ceiling speakers got connected to a high output or main amp. but try removing all speakers first then turn the unit on. see if it does power up.
May 22, 2008 | Harman Multimedia AVR 245 7.1 Channels...
Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Oct 19, 2007 | Harman Kardon AVR 100
Harman Kardon AVR 230 6.1 Channels Receiver Logo
141 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
