Question about Acer TravelMate 283LC Notebook
Battery not charging
The battery does not charge. I have bought a new battery but found out this is not the problem. Is there anything I can do without sending it into the shop?
Thanks,
Blake
My Lumia 520 is dead! It wouldn't charge, so I bought a new battery, the battery worked till it drained now it won't do anything. Checked the battery points & charger entry, don't know what else to do
Hi , you have to check that you might need a new battery charger. The new battery the bought had a charge then you used it up it sounds like your charger might have the light on but is not charging.
Dec 27, 2015 | Nokia 5700 Cellular Phone
Powerbook g4 will not start on battery tho battery is fully charged. Will start on AC.
Are the contacts for the battery on the laptop good, no corrosion or anything?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Jun 04, 2012 | Apple PowerBook G4 Mac Notebook
My battery died, tryed to charge and it wouldnt thought it was the charger so bought a new one and it still wont do anything. No charge no lights no boot
pull the battery out and unplug from power, Hold the power button down for 30 seconds (really hold it down for 30 seconds :-D ). Put the battery back in and reconnect charger.
May 03, 2011 | ASUS Eee PC 1000H Laptop
Just bought a new battery for my everex stepnote and it will not charge the battery
The charger is at fault if the battery does not charge
Replace the power pack. Many inexpensive ones are found on Ebay which are brand new for $10 on average
Aug 08, 2010 | Everex StepNote SA2050T Notebook
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Battery won't charge
A couple of things could be the problem.
A special circuit detects when the battery needs charging, it is suppose to charge the battery, that could be bad.Sometimes, a special circuit charges the battery WHILE playing the movie.
The battery could be 'dead' not charging and the same circuit tells it to bypass charging and go directly to turning on the set.
If you got it from a person that has the knowledge, they could have bypass the charging circuit and wired it to just turn on.
You did not say that you got it new and in 'charging ' working order.
Usually the batteries have to be replaced after a number of charging. [you did not say how long you had the machine.
If you know how to do it, replace the batteries. If not get someone to do the job.The cost of batteries and labor.
Oct 25, 2008 | Philips Magnavox MPD845
Battery charg not charging battert
Found this tip on another site. Connect a PP3 battery to the Exilim battery for 30 seconds. (+ to + and - to -) and then refit to the charging cradle and hey presto, it worked!!! My guess is that it is due to battery being totally flat, and the trickle charge from the charger, isn't enough to get it going. This could also explain why some new baterries have the same problem.
Jun 24, 2008 | Casio Exilim EXZ75 Digital Camera
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Sep 14, 2007 | Panasonic X700 Cellular Phone
E115 Won't Hold Battery Charge
You might hook your charger up to your battery and check the voltage that you are getting when it is fully charged. It may be that the charger is bad. Your voltage when fully charged with the battery on it should be a little over the rated voltage of the battery. Just a thought. Be sure you are using the correct poweradapter/charger also. Reply With Quote
Sep 06, 2005 | Casio Cassiopeia E-115
Acer TravelMate 283LC Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
