Question about HP LaserJet 1320n Printer
My printer hp laser jet 1320 not picking the paper from the tray.
  • tonersmart May 11, 2010
    Make sure your paper is all the way forward in the tray and in contact with the front of the tray.
    If it is not, adjust the block in the rear of the tray to LETTER size.
    Try to print a demo page; look in the rear of the machine into the rear of the paper tray with a flashlight while it is trying to print.... Is the pickup roller rotating?
    If the pickup is rotating but not pulling the paper forward, you will need a seperation pad, verrrry easy.
  • fixya726 May 11, 2010
    Does it act like it is trying to pick-up the paper? Does it pick it up and jam?
    Scholar:
  • 118 Answers
This is usually the paper pickup roller being worn. Needs replacing with new or you can also take the old one out and rotate the rubber tyre a little so that the worn area is not at the paper pickup point.
Posted on Aug 06, 2009
    Problem Solver:
  • 5 Answers
Can you hear if the roller mechanism is kicking in? If you hear the roller moving but the paper is not even starting up the path, it's probably a worn pickup roller. If the solenoid is firing but the roller isn't turning then the feed roller shafts clutch mech is probably worn/broken and needs replaced.
Posted on Jun 21, 2009
Hp laser jet 5025 paper jam
Clear the paper jam...
Also make sure all the pick up rollers are not smooth, if they are replace them. Also make sure the tray is set to the right paper and not offset. A lot of times people slam the tray and it moves the setting bar.
Jul 09, 2012 | HP LaserJet M5025 Printer
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
Have a problem paper tray will not go back in printer on 1320
Flip the tray over, there is a little pawl there that locks it down to insert it (In the center, near the front), it is held in place by a spring and often that spring pops out.
Nov 19, 2010 | HP Laser Jet 1320 Printer
I'm getting paper jams on the duplex whats the
chek inside printer for pieces of paper or something...try to clear paper feeders...Good luck
Aug 14, 2009 | HP LaserJet 1320 Printer
My 2003 laser jet 1320 suddenly quit printing.
Good chance something is wrong with the tray, are you able to print of you place paper in the multi-purpose tray (tray 1)?
If so, one thing that may be your problem in tray 2 is here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974
Feb 28, 2009 | HP LaserJet 1320 Printer
Only the orange light is on
the feeding tray having foreign materials sruck the paper loading
Jan 04, 2008 | HP Laser Jet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
341 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
