Question about Samsung Televison & Video
DLP LOST COMPONENTS 12&3
Lost signal to all components 12&3. First I lost 2&3 then I got a new cable box and now I have lost component 1. I moved my TV a few feet. When I plugged the cable box and TV back in, I had no "UNSUPPORTED MODE" on my screen for component 2&3. I had a cable tech come out and install a new cable box. Now it reads "NO SIGNAL" on all three components. I'm watching TV through vidio 1. Is there a fix or am I doomed?
Smsung 56" DLP Model # HLN567W.
  • 2 more comments
  • xring12 Dec 18, 2008
    The "component" I'm refering to is the 3 sets of color coded wires in the back of the TV. To get HD, you have to plug into the component connections. When you press the video/source button, you get a menue of component 1 component 2 component 3 & video 1 video 2 & antenna
    The "component" I'm refering to is the 3 sets of color coded jacks in the back of the TV. These are where you plug the cable box in to get HD. If you press the "video/source" button on the controller. you get a menue of Component 1, component 2, component 3, video 1, video 2 & antenna
    When the cable guy came out, I saw him go into the input menue and it was on component. He told me to unplug the TV over night and it might reset itself. Does this make sense?
    It was bad news, but I believe it is accurate. I was afraid that this was the problem but I thought I would take a shot.
    Genius:
  • 2,920 Answers
Try to connect each component i have the same setuo on my tv ans sometimes they can be confusing to hook up into the componenets have to be hooked in a certain way or they wont work.
Posted on Dec 18, 2008
    Genius:
  • 1,199 Answers
This sounds like the signal board is fried and will need replaced (this is the only fix!)
  • 679 Answers
Long shot but it's Christmass, did you have to set the input type in the dlp? I have a fta box that you need to set the input type, I had it on an svjdeo, and realized that I was using "component", looked at the settings menu and changed it to component and bingo like magic it worked. That sounds like the message you are getting also, make sure that your new box has the proper settings by going into the menuand the user options, let me know how u did ,Peace, Gym
    Sergeant:
    Champion:
  • 247 Answers
What is each component? cable box, stereo, tv?
  • 2,335 Answers
The signal board will need to be replace or you can remove the back panel cover and check all the wiring inside to make sure that are tightly connected to where they suppose to be.
The siganl board is the one where all the video and audio connections are.
  • Jaime Hernandez Dec 18, 2008
    Check this website or contact them to see if they have the board number for your TV. The board part number should be printed or have a label with the part number.
Sony Trinitron XBR 36 in (TV control on Top Middle of set) (set-up / tv/video / vol / channel / power) when set is powered on the standby/stereo light Continuous blinks red once a second, no pausing -...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is exactly as you have described .....after few seconds picture comes slowly & immediately (after few seconds). it gets off only red light blinks............ .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ..since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Jul 24, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tx-sr606. Signal lost to TV on HDMI Out. Coming in from Component Video or DVD or Game Components. Audio is playing but I get no signal to TV. HDMI Cable is fine. usually have to turn it off or unplug...
Check the most popular solutions.Also check that if you give the receiver some time (in my situation at this moment about 10 minutes) after you turned it on an selection of source.
I just received the new capacitors from a German store and will install them 2 weeks from now.
Rgrds,
Phil
Jan 25, 2011 | Onkyo TX-SR606 Receiver
How do i get a picture thru component 2 so i can get 1080i quality. i only get a picture thru component 1.
You would need to unplug the input cables in the TV and move them to component 2 on the back. Assuming your input is at 1080i in the first place (ie, the cable box or digital satelite signal is coming in at the proper resolution). One way to check is to connect an external DVD player to the component 1 input and see if the picture is higher quality than the signal from the Cable/Satelite. Not sure changing to component 2 is going to make a difference. Good luck and let me know what happens!
Nov 04, 2010 | Akai PDP5090 50 in. HDTV Plasma Television
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
What is a 5 Volt Reference Circuit ? this is a problem on my chevy malibu a 1998
a reference circuit is a reduced voltage(less than 12) that is current controled
without it your car may suddenly accelerate smply by you turning
your heater or Ac on (the battery voltage changes )
it's used on many cars for the sensors like the throttle posisition
or Map
if the fault code says you lost it
you got a shorted wire or sensor somewhere on the engine
consult your vehicles engine wire diagram to see what sensors run on 5 volt ref
then start lookin and unhookin
(chiltons avail in most public librarys has a good wire diagram)
Jul 15, 2009 | 1998 Chevrolet Malibu
No signal
Sorry it took so long for you to get a reply to your request for help.You have had a component failure in the system. This type of problem requires a qualified satellite service technician. He will have to test each component in the video signal pick up to see which components may have failed. This will be done with signal tracing equipment and testing meters to test the signal path and strength of the signal.The power overload may have taken out some internal signal processing circuits. I hope this information helps you solve your problem. Thank you for using FixYa and have a nice day!
May 15, 2009 | RCA DIRECTV Satellite Remote Control
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Mar 07, 2009 | Samsung LN32A330 32 in. LCD TV
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Denon D-90 Hi Fi - have lost interconnetion leads
Gents - not sure where you live, but try these UK links. The D65 was a similar system produced a year or two earlier, if the cable is 15 pin my bet is it is the same cable. Good luck, better look after my cables carefully!
http://www.chsinteractive.co.uk/electrical-components/misc/d90-cable-system-connect-13pin.htm
http://www.chsinteractive.co.uk/electrical-components/misc/d65-cable-system-connect-15p-d.htm
Nov 18, 2008 | Audio Players & Recorders
Televison & Video Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
