Question about Sony Playstation 3 (PS3) Console
I connot connect in internet eithernet not ditected
Hi my ps3 keeps saying eithernet cable not detected. but its plug in, its a 60gb ps3 and also connection error 80010201. and when i try to set it whren i went to easy after i selected it keeps sayimg checking for system configuration for like over 10 minutes, sometimes even longer so i just cancell it. rebooted router and modem also the ps3, still disame. pls. let me know your advice. thank you so much,!!
  • davesc Jan 04, 2009
    No longer able to connect to Internet. error 80010201 when using ethernet cable, cable replaced and green light is on at ethernet port. Error 80130128 when trying wireless. PC works ok on hub, have tried auto and manual settings. Wireless controller has also stopped working. Is this a hardware failure, if so which part would disable the Ethernet port, and the wireless connection.
  • Lalit Varadpande
    Lalit Varadpande Jan 14, 2009
    help!!!!!!!!
This will work: first thing I'd do is change your DNS settings on the PS3 to the open DNS numbers which are 208.67.222.222 and 208.67.220.220
Posted on Jan 06, 2009
How do I hook my ps3 to the internet using a eithernet cable.?
http://boardsus.playstation.com/playstat...
That website has a great guide on how to setup your ps3 for internet connection.
This is what you need to hook up to the net for your PS3
1.You need a MODEM which is the "box thing" that connects to your pc.
1. You need a ROUTER which connects to your MODEM and in to your PC. The router allows for both the PC and the PS3 to use the internet at teh same time. Unplug the wire that goes into your PC and plug into your ROUTER so that the modem is connected to the router not the PC
3. You need to connect your PS3 to the router with an ethernet cable and your PC to the router with an ethernet cable
4. Go to that web site and follow the instruction on how to set up and account on your PS3 and get going online and have fun!! Good luck!
Mar 30, 2011 | Sony PlayStation 3 40GB System
I have connected my PS3 to my computer using an ethernet cable, but it keeps saying its not plugged in on the screen.
if you're trying to have internet connection on your ps3, you're not supposed to connect it to your computer, you need to connect it to your internet modem using either ethernet cable or wireless. hope it helps.
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
I have a PS3 in one room and my computer and internet in another. I have bought a wireless router but it is hooked up in the room with the computer. I don't want to have to run a cable to the other end of...
Check your wireless network name in your computer if it is wireless enabled.
Then go to your PS3. Go into the network settings and check if the wireless connection is detected.
When you check the network settings, make sure that ip and dns settings are set to automatic.
After that you would need to open some ports on the comp for your PS3 so that you can play online.
Also let us know the make and model no of your router so that we could tell how to open the ports on the router GUI.
Very first thing your PS3 should detect the wireless connection on it.
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Can you hook up the ps 3 to the internet router to get online with out using a computer
do you have a wireless router?
depends on how your internet is set up
but if your internet is set up like this
internet plug on wall>>>wireless router>>>>main computer
then you can connect to the wireless router without having the computer to be on
if you can use the wireless internet using a laptop then i dont see why it wount work for the ps3
if you dont have a wirekless router and your internet router has several eithernet ports then you can run a either net cable from the router to the ps3
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
How do i hook the wirless router know how to plug up just cant load the cd and everytime i try to get on the internet it keep saying the eithernet cored is not connceted can someone help me
Set up the router on a real computer first, then sign onto wifi with the PS3. Be sure you know the security settings so that you can easily match when connecting from the PS3
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
Trying to get online but cant
You have to make sure that the router isn't still loading, to unload it you need to hook the internet to a local computer in your house. Just get on any website and then hook it up to your PS3 and it should work.
Need help with ps3 internet hook up
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
3G USB Modem internet not working on PS3
erm...cant you just plug in your 3 usb to your pc and connect to your ps3 via the ethernet cable? that should work...but i think the main issue is that it might be too slow to play online...either that or you play online for ten mins and then your done for the month lol
Dec 20, 2008 | Computers & Internet
PS3 internet problem
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
763 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
