Question about HP OfficeJet d145 InkJet Printer
HP Officejet d145
I was attempting to do a 2 sided copy of a 2 sided original and the original has jammed in the feeder. I can't seem to get it out. Can you help? Any insights appreciated. Thank you. Please e-mail to kevinj.ledger@gmail.com. Thanks again
Hi, When I get a paper jam I have to remove the back and get it out from there. See if that helps. Also in the manual there's page telling you how to get jammed paper out. Good Luck, Carol
Posted on Apr 08, 2007
What does "Original Jam" mean and how do I fix it?
Your "original" document -- the document that you are trying to copy, has jammed inside the printer's sheet-feeder.
Remove all the pages of the original from the "input" tray, and then look for a "missing" page -- one of your original pages is "jammed" inside the printer.
Jun 10, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Hp officejet 5610 All-in-One ADF automatice document feeder jams
where is it jamming. Clean the rollers with a toothbrush and water, horizontally.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Ricoh Aficio 1035 ARDF is not duplexing, why?
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Sep 30, 2008 | Ricoh Aficio 1035 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Cartridge jam
There are clips under the feet, get a torch and u can align them both and push down at the same time, they will click in. To test it make sure there is only frontal and backward motion, one is out still if it moves side to side.
Jun 04, 2008 | HP OfficeJet d145 InkJet Printer
Original document stuck in feeder of HP OfficeJet 6110 All-In-One
ok...this is not that hard...you'll need to open up the top of the machine, and most likely remove some components. Take a look at this link first though Got backup?
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 7410 Scan feeder jam
ill see if thera sev maneul out for u best to unplug it all 2 min then back on with latest drivers what kinda paper are uusing sum are picky to thin ect
Jan 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
