Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Limit switches how to check a limit switch
  • 96 Answers
Take Ohem meter and check
Posted on Dec 19, 2008
Fire department says it is leaking at pressure switch, does this unit have a unloader valve and a check valve?
It would have to have a check valve and a unloader valve or it could not start again with any air pressure in the tank. The unloader is in the limit switch, should see a small plastic air line going into the limit switch, when the limit switch shuts off the electric motor it drains the pressure in the cylinder so there is no load on the compressor so it can start, so if there is air coming out of the unloader when the electric motor is shut off it is the check valve if it is coming out all the time even with the motor running it is the unloader in the limit switch.
Apr 21, 2016 | Air Tools & Compressors
How to check high limit switch on theme Hester
turn all power off. remove both leads to high limit switch. take a multimeter, set it to OHMS......put leads across high limit switch....if u get a reading then switch is closed. if you get no reading then switch is open
May 04, 2014 | Rheem 266K to 399K BTU Swimming Pool...
What does fault code f03 mean in miele g7881 washer?
Wash water
temperature T3 in
wash block CHDESIN
not reached
within 60 minutes
Temperature limiter F2 has
cut out
Reset temperature limiter F2. See
Resetting Temperature Limiter F2
(Thermostat), 030 4.2. If necessary,
replace the temperature limiter. See
Replacing Temperature Limiter F2
(Thermostat), 030 4.3.
Heater elements do not heat
up
Check heater elements. If necessary,
replace a faulty heater element; see
Heater Element Replacement, 030 4.5..
Heater level switch does not
switch
See Heating Level Switch Does Not
Switch On, 050 3.1
Voltage (6VDC) from the
electronic not present. The
heating level switch controls
the heating relay voltage.
Check plug connections.
Check electronic module output voltage;
see 070 Fig. 5, Pos. 9.
Nov 08, 2013 | Washing Machines
Honeywell S9200 causes transformer death when limit switch attached
If jumping 1 to 7 is blowing the fuse it sounds like a bad board.Not familiar with those but as you said, normally closed limit would be the same as a jumper. Check your dip switches first but I'm thinking bad board/direct short.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 24, 2017 | Honeywell Heating & Cooling
Limit switch code flashes no inducer motor or ignition starting
usually the main blower runs non stop when limit circuit opens. Shut off the power and check each limit with the wires removed. Use your meter, check the same way as you would check a fuse. Sometimes you can tap on the main limit to reset it. Some secondary limits have a small plastic reset button in between the wires. Check this also.
Nov 27, 2011 | Goodman Heating & Cooling
I have a dyno glo rmc-fa100dlx forced air heater. It will light and work for a few minutes, up to about 5, then it will stop heating and the fan will keep blowing. any ideas? thanks!
If the unit comes on and runs but then shuts down, that sounds like an indication of a high limit trip.
Most, if not all, furnaces have high limit switches that keep a constant check on the temp inside the furnace or air handler. On most systems, once this high limit switch has been made (got to hot), the limit switch breaks control voltage to the heating device (strips, gas, fuel, etc.etc..). The blower motor continues to run until the high limit has dropped in temp and reset itself.
On some models, the high limit is a manual reset, meaning you need to reset the switch yourself or shut the unit off and then back on to reset it.
Check all filters and replace as necessary. Check the coils and fan blades for dirt build-up and cleanliness. Check motor belt (if applicable). If all these fail to solve the problem, then your issue either lies within the blower motor itself not moving enough air for proper heat transfer. Or the high limit switch itself is failing.
Jan 09, 2010 | Heating & Cooling
Dryer is not getting hot, why??
The element most likely burnt out. light a filiment in a light bulb, they do burn out. The other possiblity is the limit switches are no long working, you can check that by connecting the 2 wires that go to each limit switch, iff more than one limit. Or checking continuity across the switches. Unplug the Dryer first of course. If it is the limit switches it will run without, but replace as soon as possible to prevent overheating.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Goodman GMP125-5 limit switch open
There may be as many as 6 limit switches on the furnace. The first thing to do is turn off the power to the furnace. Look around the burner box. You will see possibly 3 small maybe brown plastic swithes with two wires to each and a button between the wires. Press the button on each one. If it clicks that's the one tripped. There may also be the same kind of switch(s) in the blower compartment. There's a self resetting limit on the middle of the furnace it also has two wires but looks like a black or dark brown plate about 2 1/2 X 3 1/2 inches. You have to check that one with an ohm meter. If any of these switches are tripped there is a reason. Check your filter and overall air flow. with low airflow the furnace may overheat. The switches around the burner box are roll out switches. Watch to see if flames are coming out of the burner area. especially when the blower comes on. DO NOT bypass any of these switches. Call a certified tech. to check it out.
Mar 02, 2009 | Goodman CLJ30AR32 Air Conditioner
Limit Switch
It is rare that a limit switch goes bad. It is a safety control. If it is shutting off your furnace there is a problem that it is protecting you from.
If the limit switch is shutting the unit down your furnace is overheating. Check the filters. Check for any obstruction in the blower assembly. Check to see if you can raise the blower speed. Make sure all registers are open in the house. Your evaporator coil could be obstructed if you do not take good care of your filters.
Feb 28, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
37 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
