Question about LG WFT1071TP Top Load Washer
WHAT IS THE SOLUTION ON ERROR MESSAGE PE IN MY FUZZY LOGIC WFT601
IT DOES NOT START ANY PROCESS,IT DISPLAY ONLY PE AT MESSAGE PANEL AND WITH BUZZER SOUNDWhen you press any button all the four lights for load flush on and off with the buzzer sound
    Brigadier General:
  • 5,158 Answers
PE = PRESSURE SENSOR ERROR
• The SENSOR SWITCH ASSEMBLY is out of order.
it needs to be replaced
Robert
Posted on Dec 18, 2008
  • Roberta Smith
    Roberta Smith Dec 18, 2008
    I did look up the part herehttp://www.repairclinic.com/SSPartDetail...
    not horribly expensive and possibly replacable just by removing the rear cover although i would have to see it as the service manual isn't that clear about it.
    Robert
  • Roberta Smith
    actually i found this comment / suggestion as well
    "This could also be caused by to much soap being used or the wrong kind.
    If you are not using HE rated soap, do so and dont use a full cup of
    soap, front loaders only hold about 10 gallons of water, avoid using
    washpowers use liquid soap. if that dosent clear the problem you may
    have a problem with the sensor or a connection."
Error Code PE
go to the manufactures website and download the user manual and check in trouble shooting guide eric
Jan 19, 2018 | LG Washing Machines
Fuzzy logic washing machine 12.5kg. What does PE code indicate?
PE pressure level switch error. This monitors the water level. It has a tiny hose connected from the drum. Could be blockage in the hose.
Feb 16, 2016 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
How do I fix PE Error code for LG Washing machine fuzzy logic
PE means pressure error. The water pressure sensor is reporting too much water in tub. It can be bad sensor or too much water is really in the tub. Too much water is caused by water not being pumped out. Kinked line. Bad pump. Etc. or inlet valve not shutting off. Does it seem that there is too much water in tub? If water level seems good and if tub fully drains, the water pressure sensor probably. Good luck.
Mar 03, 2015 | LG Washing Machines
What is a PE error on LG fuzzy Logic? beeping at the same time
Pressure switch fault......could be just blocked pipe!
locate pressure switch under top cover....far right corner, disconnect thin rubber pipe and blow through it to clear any blockage......might be lucky!
Oct 19, 2014 | Washing Machines
How to reset eprom for PE error
Hi, PE error code means there is an pressure sensor error in your machine .You need to check pressure it will be giving incorrect indication . Pressure switch is faulty you need to change it . Procedure for changing is : 1.Power off the machine remove backcover and top cover. 2.The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. 3.It generallysits just under the top cover.
Apr 08, 2010 | LG WFT1071TP Top Load Washer
There is a round clean out door accessed from the front of your unit. Some models you have to take the lower panel off entirely to clean it out. It unscrews and probably there is anything and everything you can imagine clogging the pump inlet....thus the error message "PUMP ERROR" THe unit's error code may manually have to be deactivated in the control panel to reset the unit to normal operation.
Nov 30, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
453 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
