Question about Zenith Z46Z70V 46" Rear Projection Television
TV Shuts Off On It's Own
I have a 47" Zenith rear projection TV. Recently (about 2 weeks ago) the bulb blew out on it. Well before the bulb went out, the TV use to turn off momentarily, then come back on. We figured it was because the bulb was on it's last leg. Finally, it popped, fizzled and went out, and we replaced it. Now, the TV is still turning off, but this time it's turning off for longer periods of time. Before it use to only be a couple of seconds, now it's about 2-3 minutes. The light (indicating if it's on or off, usually green or red) turns completely off, like there is no power to the TV, a few minutes pass, and it turns back on by itself. I have no idea what to do next.
smarthome2
  • 1114 Answers
SOURCE: 52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
Posted on May 17, 2009
ladywinn
  • 5138 Answers
SOURCE: zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Posted on Jul 20, 2009
johnnydiode
  • 647 Answers
SOURCE: Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Posted on Sep 22, 2009
  • 5 Answers
SOURCE: when trying to turn on my tv, the green light
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Posted on Jun 12, 2010
SuperTech-11
  • 1591 Answers
SOURCE: A friend gave me a Zenith LCD projection tv. model
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 29, 2011
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Very dim picture
Ur tv have been in use for at lest 4 or 5 hours a day the last 1 1/2 or 2 year?The projection bulb life it over.Require a new bulb.
May 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
No video on my Zenith E44W46LCD 44 in. Rear Projection TV
your tuner circuit has failed not to worry though just look fot the fuses as the one that controls the tuner has failed replace it
Apr 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
WORKS 3 MIN AND SHUTS OFF
If it is the power LED that is flashing orange 2times every five seconds , it suggests that the Lamp Cover was not reinstalled correctly. Remove and reinstall it
Jul 13, 2008 | Panasonic PT-50LC13 50" Rear Projection...
TV does not respond to Remote
follow wire from sensor inside tv to tuner board and resolder.
Apr 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Changed Lamp, But not as bright as before!!
Just had that problem wrong lamp used orignal lamp fixed problem
Feb 21, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith HD 44 inchr red lamp light is on
sir,,,maybe,,,,,but you said your tv is ok soo i think its just alright,,,thnkss
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
