Question about Sharp R-1480 Microwave Oven
How do I uninstall an old Sharp R-1450 Carousel over the stove microvave oven? I removed the screws from the top that it hangs on and it still won't move. Help and Thanks.
  • 8,197 Answers
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
Good Luck
Posted on Dec 18, 2008
Try removing the filters beneath the microwave. Youll find a large screw at roughly a 45 degree angle on each side. These screws bolt the microwave to the mounting panel in the rear.
Posted on Jan 02, 2009
  • Quentin Scholl Dec 06, 2011
    Yep, spent about an hour trying to figure it out and surfing the web and sure enough, found the 2 bolts. Thanks buddy!
    Yep, that did it! Thanks for the tip!
Briggski is right. I just removed my Sharp Model R-1450, and would never have found those two 45-degree bolts without his/her help. Those bolts are not obvious; they run diagonally, just inside the side surfaces, about 18" from upper rear to lower front, and their heads are toward the front of the unit, just above the air filters. I spent over an hour trying to figure out how to uninstall the microwave before conceding defeat and tuirning to the internet for help. Thank you, Briggski!!
Posted on Nov 02, 2011
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
Sharp carousel door often won't open when I push the door release button in.
Take the cover off end take a look how the hinges are mounted on it, If they are bolted on they can be readjusted, He man, Use your brain .
Oct 21, 2012 | Sharp Carousel Microwave Ovens
Sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Dec 27, 2009 | Sharp Microwave Ovens
Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Oct 14, 2009 | Sharp Microwave Ovens
How do I remove a sharp carousel over stove microwave oven?
So we can help you, please create a NEW FixYa post with your full model number from the unit.
We have several manuals, and may have the one you need.
If so, we will give you the link to it at no charge.
Oct 11, 2009 | Sharp R-820B Convection/Microwave Oven
Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
Sep 28, 2009 | Sharp Microwave Ovens
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Remove over the stove microwave Sharp R-1462
Ther are 2 long screws at the top on the left and right side in the cabinet.Remove them carefully it is heavy and will drop hard if you do not hold it while you remove them.If it does not come off then there maybe a release handle on the top left part of the vent you must look carfully hope that helped:)
May 18, 2009 | Microwave Ovens
Sharp R-1480 Microwave Oven Logo
1,054 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
