Question about JVC Cybercam GR-D90 Mini DV Digital Camcorder
Jvc gr-d90 mini dv
Message : condansation please wait
j'attend plus d'une heure mais le probléme ne se régle pas
que dois je faire svp
merçi beaucoups pour votre précieuse aidePlease Wait
Condensation
Operation Paused
Camera has been on for many hours and still reports condensation. Camera was never wet and is in a dry climate.
  • darr69 Dec 25, 2008
    Where can I send my video camera to fix this problem. I live in Central Idaho, far away from anywhere. And, can this problem be repaired for less than the cost of the video camera?
    Thanks,
    Darr
    Genius:
  • 2,920 Answers
Use a blow drier on it to clear out the condensation it may have in it could save you the cost of repairs
Posted on Dec 25, 2008
    Sergeant:
    Novelist:
  • 327 Answers
  • just click the link below
  • http://www.advancecamera.com/repair
  • the link will help you to get the device repaired and serviced
  • Free estimates.
  • Reasonable rates.
  • Fast, friendly, and personal service.
  • Top quality repairs.
  • Advance Camera 1 Year Warranty.
  • 10,594 Answers
Most probably its dew sensor is bad and giving signal of condensation to system control chip.
You can give try to blow hot air from hair dryer with enough distance in camera mechanism to evaporate any moisture inside, if any.
Posted on Dec 18, 2008
  • Shahid Electronics
    Shahid Electronics Dec 25, 2008
    Click on JVC Global Support and find nearest JVC repair center.
    push reset button on camera so camera will select factory default settings and then check.
    Brigadier General:
  • 5,158 Answers
Remove the battery for about ten minutes to reset it and try it again
  • Roberta Smith
    Roberta Smith Dec 18, 2008
    réellement du message d'erreur vous pouvez devoir décrocher la batterie et toute la puissance pour une heure au moins.
Donnez-moi une solution pour mazda bt50 et puis il va demarrer le moteur serra le pont que dois- je faire pour ne pas tremble plus
Sorry but the UK stopped talking french in the 14th century at court so everyone had to speak that horrid anglo saxon language called english .So please re-write in a sub human languagecalled english please for a answer
Feb 22, 2013 | Mazda BT50 Cars & Trucks
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Bonjour ou se trouve le reste sur ce modele?? j'ai DEG de programme dessus et je ne suis pas capable de l'enlever. merci
écoute, ne te fâche pas : je ne comprends pas le sens de ta question et je devrais m'abstenir de te venir en aide, craignant d'interpréter incorrectement ton problème (et ce n'est pas ma maîtrise de la langue de Molière qui est en faute!!) Mais je vais quand même essayer de t'aider.
L'indicateur DEG que tu sembles vouloir éradiquer est parfaitement inoffensif. It est affiché sur l'écran pour te rappeler que l'unité d'angle est le degré. Cela signifie que tout argument que tu fournis à une fonction trigonométrique (sinus, cosinus, tangente, cotangente) est interprété comme une valeur en degrés. Donc si tu calcules sin(Pi) ne t'attends pas à obtenir 0 mais le sinus de 3,14.. degrés.
De même, toute valeur retournée par une fonction trigonométrique inverse ( arc sinus, arc cosinus, arc tangente, arc cotangente) sera en degrés.
Si tu changes l'unité d'angle de degré à radian, l'indicateur RAD sera affiché quelque part sur l'écran. Donc je te suggère de ne pas t'acharner à faire disparaître cet indicateur: Il ne fait que te monter quell unité d'angle tes calculs utilisent. C'est plutôt commode, ne trouves-tu pas?
Maintenant, si tu veux préciser ce qu'est ce reste que tu cherches, peut-être pourrais-je t'aider? Tu n'as qu'à faire un commentaire et je verrai ce que je peux faire.
Jan 17, 2010 | Casio FX-250HC Calculator
J'ai un appareil photo numerique canon powershot s300 digital elph et il ne s'allume pas il a ya un ecran noir ou il est ecrit " changer la batrie" dois-je acheter une autre baterie ?? de plus, je n'ai pas...
Pardonnez mon français, j'utilise Google. Oui, c'est mai-être temps d'acheter une nouvelle batterie. Batteries rechargeables ne sont pas faits pour durer éternellement. Ils devraient être remplacés tous les deux ans. Si votre batterie est plus vieux, alors il est temps. Heureusement, le NB-1LH batterie est disponible à partir de sources génériques de ces journées, et est relativement bon marché si vous recherchez.
Oct 31, 2009 | Canon PowerShot S300 / IXUS 300 Digital...
(HELP WANTED) allo jai un petit probleme de IBM 2.6ghz thinkcentre ,dvd rom,3 hard drive de 60g ,512 ddr 3200 . Le probleme est que mon screen s' etaind apres un lap de temps , mon cpu fan arrete...
sons si le cpu cooler ne fait pas son travail, plus de chauffage et dur arrêté.
mieux supprimer radiateur et une nouvelle pâte thermique
ou qui a le mal ou pas les pilotes de système de mémoire
essayez d'utiliser 1 bâton de ram
Aug 06, 2009 | Computers & Internet
Mon appareil canon ne marche plus!
Salut
Desole, mais mon francais est tres mal... Votre objectif a été endommagé dans la baisse et doit être réparé ou remplacé.
J'espere que ceci aide.
Thomas
Sep 19, 2008 | Canon PowerShot A550 Digital Camera
Jvc gr-d90 mini dv
Just turn it on and leave it like that for about one hour. It will clear by itself.
Jul 13, 2008 | JVC Cybercam GR-D90 Mini DV Digital...
Contr?leur IDE VIA PCI Bus Master
Quelle est la marque et le modèle de votre ordinateur?
Jan 11, 2008 | Microsoft Windows 98 for PC
Une image plus claire S.V.P
Please call Jazz Products @ 732-572-7050
Nov 01, 2007 | Jazz DV-179 Digital Camera
JVC Cybercam GR-D90 Mini DV Digital Camcorder Logo
37 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
