Ac hasn't worked all summer put in freon and only blows cold air out of passenger it gets a little cooler on driver side as your driving but not as cool as passenger side
Check the air vent of passenger side for any obstruction and secondly keep your thermostat full towards cold side make sure the ventilator is fully closed position and rotate the air selection knob clockwise and anti clock wise two three times than set it at the required position mainly your air selector seems to be malfunctioning there is nothing wrong with the ac
SOURCE: ac blowing hot air
the blend door actuator located on the air box (right hand side under dash) is prob. inop. worst case senerio the blend door its self is broken. I have replaced the actuator more than anything.
SOURCE: air conditioner problem with 2005 chevy 1500 silverado
I have the same problem exactly, if i turn off the ignition and then turn it back on it begins blowing cold air again. I would like to know what the problen is as it sounds like it is not unique to just my vehicle.
SOURCE: 2004 Chevy Silverado AC is blowing warm air on passenger side.
You have dual zones that are controlled by temperature actuators the passenger side has lost its memory or has gone bad you can put it in self programming by disconnecting the battery for ten minutes then hook it back up start the truck turn the temperature control on but do not touch any other controls let it go thru the self programming for about 6 to 7 minutes then select your temperature you want if it still does not work properly you may have a bad actuator or a bad connection at the actuator
SOURCE: 2005 Chevy Impala driver's side heat blows cold.
First....buy a drivers side air flow actuator at a auto parts place for dual zone heating/cooling.
(NAPA etc will have it.....or the dealer)
Open the glove compartment.....all the way....you may have to take the screws out at the bottom......look in at the heater assembly....look over to the left....you will see the two air flow actuators.
Look at the part you have and match it to the part on the heater assembly.
The actuator that is closest to the engine is the drivers side control.
Replace it.
Try your controls and check for heat and cooling on both sides.
The stepper motor in these actuators goes bad on quite a few...but over look that.....you have a great car,good for many miles of trouble free driving.
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
These will help.
Thanks.
