E0000713-0004 This is an intermitten error code we keep getting on a canon 6800 with an R-1 finisher. we even swapped out the finisher and the code still happens. We swapped out the main board on the copier as well as the harness that goes to the finisher.
  • 1 more comment
  • peteco Dec 22, 2008
    We swapped out the DC controller board, the main controller board, scan interface board, the wire harness from the finisher to the main control board. Not sure at the moment which one was on the rear left, but we replace the one on the left and right. Lastly all the firmware has been updated. I look forward to hearing your suggestions. Thanks!
    you are correct. no finisher copier runs without a problem. at this point we are thinking there is a pinch wire, but its wierd that this problem just came up... not sure how a wire got pinched. before this problem came up, it was 3 mos before the last svc call. So it wasn't tech induced, (they can be the hardest problems).
  • peteco Dec 23, 2008
    Limitted functions mode is not turned on.
  • 76 Answers
You already replace the finisher accessories power supply PCB on copier? if not try to check that board.
Posted on Jan 03, 2009
  • 168 Answers
If you swapped the finisher and still get it that means it is in the copier ....you said you swapped the board is it the one on the left rear..
Posted on Dec 20, 2008
  • andzulisv Dec 22, 2008
    ok you swapped the main controller and did not get a different code??? they are serielized to the copier interesting so as long as the finisher is not hooked up you dont get the code??
  • andzulisv Dec 23, 2008
    ok so have you looked and see if youat least have power to the finisher if you do that would narrow it down to the wires running from the sorter connector to the dc controller . But wait this may not be it but you might want to look under ADD FUNC common settings then the one that says limited functions mode ... you want to make sure that is not turned on you can run the machine after it detects an error ... you have to reset this feature every time then turn the copier off and on
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
How to clear a 6800 error code
It says that waste ink sponge has reached its limit.
Try the below steps.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
Now press resume button 4 times,then press the power button, if the ink smudges you have  to clean that toner sponge
Jun 09, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Hej I get an error code 6800 Regards Ivan
Service error 6800 means that a problem occurred in reading from or writing to the EEPROM. To fix this you need to replace the logic board. For replacement you can try http://www.partsalliance.com or http://www.ppsnj.com
Mar 20, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Error E000020-03a2 canon c6800
pls check the cyan deverloper if it irc6800.drum unit if it is irc3200
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
Canon i850, service error 6800
This error indicated that the internal printer counter for the waste ink sponge has reached its threshold. You should be able to reset this counter once without cleaning the sponge.
Do this:
3. Release RESUME
now try press resume button 4 times..after that press the power button
This should clear your error and let you resume printing. If you start getting ink smudges on the paper you will have to disassemble the printer and clean the waste toner sponge.
Jun 17, 2008 | Canon i850 InkJet Photo Printer
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
62 people viewed this question
jasbo
jasbo
