Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint wt965 f04 error
Hi i have the above machine and it has come up with a f04 code on the screen.it turns on ok then after a few seconds you get that code,can you help please.
best regards
chris
  • thecrow
    thecrow Dec 18, 2008
    thanks so much:) and merry xmas.
  • Hotpoint Master
  • 3,463 Answers
F04 indicates that the pressure switch is jammed on empty,
check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an enginner
This really is your only option.
Plz rate my solution
Thanks.
Posted on Dec 18, 2008
FO4 Error Code with Hotpoint Openspace Cooker - Explain please
Hi Theresa,
Just search online for "error code f04 hotpoint open space". You'll see a hit on fixya back in November 2011. This may well contain your answer.
Also appliance spares for your home
and http://ukwhitegoods.co.uk/
Jul 26, 2015 | Hotpoint Ovens
I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Nov 11, 2014 | Washing Machines
Hotpoint aqualtis error code F04
Indesit (Hotpoint Aqualtis, Ariston) 'F04' states 'pressure switch jammed empty, check pressure switch, wiring and module connections'.
It is not that unusual to find it cured by having the connections gently pulled apart and replaced, thus 'cleaning' the contacts back to correct operation ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 05, 2011 | Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Repair manual for hotpoint wt960p
The error code does not mean that the pressure switch is faulty, it is indicating a fault that affects the function of the switch.
The problem is actually a blockage in the pump or pump filter.
To rectify the problem, do the following.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction hers as well.
This should solve the problem
Please leave feedback for my solution.
Thankyou.
Jan 19, 2010 | Hotpoint Washing Machines
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint 1600 wt965 washing machine it has f-18 error message
Not good news - need to book an engineer, F18 is
Communication error the main module could be at fault (PCB)
This is located byhind the switches under the top, don't attempt to have a look though
Oct 25, 2009 | Washing Machines
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
947 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
