Question about Biostar P4M80-M4 Motherboard
P4M80-M4 not powering up
I'm building a new computer and have the Biostar P4M80-M4 motherboard. Everything is in place(power supply cables, ide, sata cable, etc.) and all wires from case are in the correct spots according to manual. I have a Seagate barracuda 7200 80gb hard drive and a cdrom connected. When you press the power button, nothing happens. Have checked diagrams and cable placements over and over. Have no idea what could be preventing the machine from firing up. Anybody know what could cause this? One thing that did happen was, when the case's power and reset buttons were pulled from the board, the fan started to go. I immediately turned the power supply off. Why would it start after removing the buttons? Thanks
  • Travis Wagner Mar 29, 2007
    Had thought of that and it has been tried both ways. Still didn't fire either way. Does this board require a floppy drive to be attached to fire up? Might be a stupid question but thought I'd ask. There isn't one attached to the board.
Was that really all it was ? i have the same problem you had... computer not booting with this motherboard. I have tried everything !!! remove battery to clear CMOS use the jumper to clear the cmos change the keyboard, change the PSU, boot without RAM, change the RAM, put everything on a wood table (all outside of the case). Tried with all drives connected on the mobo, tried with no drives. I even changed the CPU but the other CPU i used, i wasn't sure if it was still OK tough. I checked to see if some connections were broken or something ... i'm about to try to find the 1-800 number of biostar, or send the mobo for a refund. What else could i try ?
Posted on Apr 04, 2007
Glad to report the problem has been solved and fixed. There was soder from the board touching the case and causing a ground fault so it wasn't booting. Thanks for the help
Posted on Mar 29, 2007
    President:
  • 2,961 Answers
You may have the power and reset connectors on the right terminals, but they may need turning around, normal rule of thumb is if the markings on the connectors are on the outside, then turn them to face inwards.
Power Problem
Sounds like the PSU. Can you borrow one to test?
Nov 11, 2013 | Biostar P4M80-M4 Motherboard
Motherboard Power Problem
Hello Alienware,
Could be a few things.... such as the micro-fuses that have gone on the MB....
But what I dont understand is this:...."Then I disconnect the 4-pin cable that goes from the Power Supply to the motherboard near the CPU and the pc turns on fine"
How????
You have just disconnected the cable from the PSU to the motherboard....it CANT turn on! LOL.
Do you mean that the lights turn on?
Or you hear the HD spin up (if you left it connected to the MB that is)?
Please advise so I can help you more.
Have a replacement motherboard. After about 1 minute it powers itself off. Sometimes it does it sooner - sometimes later. Have replaced the Power supply, removed the graphics card, unplugged all...
Your motherboard is manufacturing defective. If the motherboard still under warranty, take it back to the computer shop where you purchase and demand for an exchange.
Sep 01, 2011 | Biostar P4M80-M4 VIA P4M800 Socket 478 ATX...
My SATA HDD Seagate Barracuda 7200-12 no detect on Biostar P4M80-M4 Motherboard, it is something wrong with my motherboard?
your hdd is crash or may be problem on power supply connector and cord connector try to replace it.
Apr 18, 2011 | Biostar : P4M80-M4 Socket...
Just replaced my Biostar P4M80-M4 mother board with a new one and I now have no screen. Power supply on, fans running, appears all is well but no screen?
Try replace the Memory module (DDR2 RAM) with new ones.That's should fix it!!
If still won't come out, replace the power supply unit.
Dec 09, 2009 | Biostar P4M80-M4 Motherboard
How to repair bios for Biostar P4M80 M4? Tried to update the BIOS and the computer wnt dead.
try removing the cmos batt for a couple of days and the main power connector from the main board, re connect and re try
keep me informed
Nov 16, 2009 | Biostar P4M80-M4 Motherboard
Dont know where to hook up the power and leads on the p4m80 -m4 to get power
missed placed the manual of the m935dlu motherboard having problem hooking up the panel switches the led sw, hhd sw, reset sw, suspd led and pwr sw
Jun 29, 2009 | Biostar P4M80-M4 Motherboard
Sata raid and normal mode?
There may be a setting in the bios for SATA either IDE or Raid mode
May 30, 2009 | Biostar P4M80-M4 Motherboard
Serial ata controller
Is your bios set for sata or ide
also is it set for auto detection of all drives and is the jumper on hard drive set for master.
Aug 12, 2008 | Biostar P4M80-M4 Motherboard
Biostar P4M80-M4 Motherboard Logo
447 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
