Shut Off Issue - Yamaha RX-V661
Hello tech-48,
I'm having a power(?) issue with my receiver. Everytime I turn on the receiver it stays on for appr. 2-3 seconds and then shuts off, I go through these steps 3-4 times..then the units permanently shuts off and is completely disabled. I then have to unplug/plug the receiver to turn it back on, but again stays on for 2-3 seconds, then turns off. The only steps I've done was to replace the Power Transformer (X7667-A00), which did not work, I've tried the system reset stated in the manual which did not work either. Can you possibly help? Thank you in advance.
SOURCE: Yamaha RX-v661 7.1 Receiver
Could be overloading your circuit and the receiver goes into safe mode to protect itself
Posted on Feb 12, 2008
nuwan chinth
  • 111 Answers
SOURCE: yamaha receiver rx-v661 display light is out
lamps are burnt out or missing power to backlight system.
please check all the fuses.
nuwan.
Posted on Jan 13, 2009
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
petraman7
  • 1175 Answers
SOURCE: yamaha rx-v461 not working
Does the reciever have separate speaker switches?
Try turning off the speakers and turning on the amp.
If it doesnt have speaker switches , make sure ALL the speakers are connected at both ends and try turning on the amp again.
Posted on Feb 04, 2009
smarthome2
  • 1114 Answers
SOURCE: The picture on my TV flickers on and off when I
You cannot run HDMI from any source thru the Yamaha to the TV. The V661 is 1st generation HDMI headache. Version 1.1 which basically is useless. Don't blame Yamaha, it's not their fault, it's HDMI. All manufacturer's receivers prior to 09' series use either 1.1, 1.2, or 1.2a. and they all have issues. So, here's the skinny, run your audio to your receiver via optical or digital coaxial. Then run video directly to the TV via HDMI if you wish. The problem arises when you have more sources than inputs on your TV. Depending on the size of your TV can make a big difference in how you wire it. If your TV is 50" or smaller, just use component, the human eye cannot differentiate between 720p and 1080p and that's a fact. second fact, most TV shows are broadcast in a native resolution of 720p, the only real 1080p programming is on HDNET, Discovery,National Geographic and The NFL.
What I mean by that is the camera used to take the actual picture is a 1080p camera. Major money! so, that being said, if your tv is larger than 50", and it's 1080p not 1080i yes, you can see a difference. If you post a comment and list all your product, I can give you the best possible way to put it all together. I feel your pain and aggrivation! I am a Yamaha, Marantz, Proceed, and Adcom Dealer. I get it from all sides! If there's anyway I can make it easier for you, I will. Hope this helps
Posted on Jun 24, 2009
No sound from zone 2 speakers on yamaha rx-v661
Have you gone into the speaker configuration menu and turned on zone 2?
Oct 18, 2013 | Yamaha RX-V661 Receiver
My Yamaha RX-V661 powers on when I hit the power switch. After two seconds it goes to stand by.
try holding the 'straight' and 'audio select' buttons and press power. What does it say on the front panel? Should say some kind of protect: I, DC, PS. This will help narrow down where your problem is.
Oct 15, 2013 | Yamaha RX-V661 Receiver
JVC car audio cd receiver model # KDR-310 will not stay powered up. Shuts down after 2 seconds. What's wrong??
hi marnie, if all the power and speaker cables are connected correctly, then you might have a faulty or shorted speaker in the vehicle.your unit is sensing a fault condition. check the impedance of eack speaker connected to the unit from the harness plug. if this does not help then your unit needs to be bench tested.
May 23, 2012 | JVC AM FM CD DET FACE CAR STEREO
After pressing the power button, my HP dv7-1129 laptop only stays on for about 2 seconds and then shuts off. I completely replaced the DC cable and now it receives power, but it does not boot up. What is...
try taking the battery out, unplug the DC cable and hold down the power button for 30 seconds this will get rid of the static on the motherboard which could cause the problem.
After you have done this put the battery back in, then the DC cable then try to turn it on.
If not it could be your battery because you are getting an indication that you are receiving power, try taking the battery out and just plugging in the power cable.
Hope this solves the problem.
Jul 13, 2011 | HP Pavilion dv7-1129wm Notebook
I have a RX-V661 that turns off within a second or two of turning on. Is the capacitor the problem and, if so, how can I replace it ?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 06, 2011 | Yamaha RX-V661 Receiver
My receiver will not power on. if you runplug it and again plug it in, it will stay on for 2 sec and shut off
My name is Becki, and I'm with Dish Network Customer Service. This issue sounds like a power issue. If you have the receiver plugged into a surge protector, try plugging it straight into the wall. If already in the wall, try unplugging it for 10 seconds. If that doesn't work, the receiver needs to be replaced. If this issue has not already been resolved, blog back!
Dec 02, 2010 | DISH Network ViP 211 DTV Receiver
Powersn for 1-2 seconds then shuts off
The receiver is going into protection mode. Try removing all connections i.e. source inputs and speaker connections. If the problem still continues your problem is internal and would require a trained service tech to troubleshoot and repair. More than likely the switching power supply or amplifier output is overloaded.
Feb 03, 2010 | Harman Kardon AVR 130 Receiver
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
114 people viewed this question
 Grubhead
Grubhead
