Question about Toshiba Satellite A105 Notebook
Wont start-up My A205-S5853 will not startup. It gets to a certain point and then startsover (continuously)?
  • 38 Answers
Put in your Windows install disc and do a repair installation. Your master boot record seems to be corrupted. By doing a repair install of Windows it will fix the MBR. All of your data will stay intact.
Posted on Dec 18, 2008
  • 102 Answers
What operating system are you running? Also, have you downloaded or installed any programs lately ? If so, try pressing F8 at boot to start in safe mode and uninstall the most recent programs in "add & remove programs" in control panel.
My emachines desktop el1333g-01w wont boot up windows the computer starts but goes into the startup repair screen and stays there
sounds like you need to re-install your os win xp w7 w8 its what we call rolling where the boot up gets to a certain point then forgets what to do so it just keeps going around and around hope that helps.
Jan 27, 2014 | E-Machines eMachines Desktop PC
2003 corolla No compression. Changed timing set. Still the same. What's wrong
Although the 5S-FE and 7A-FE engines are not listed as interference motors (it is not listed by the manufacturer as a motor whose valves might contact the pistons if the camshaft was rotated separately from the crankshaft) Check your piston rings,did plugs have oil on them.
Oct 25, 2012 | Toshiba Satellite A205-S5853 Notebook PC
My toshiba satellite a205-s5853 was shutting off while loading windows onto it.tried several times now when i turn it on screen is black
it need to update your system bios, download its bios from internet. and start your laptop in safe mode. ( for this when your computer start press F8). and install bios. your problem will solve.
For more details and information link is here
http://www.worldstockrates.info/category/computers-and-technology/
Aug 03, 2011 | Toshiba Satellite A205-S5853 Notebook PC
Toshiba A205-S5880 will not boot up. Turned complter on and it goes to safe mode but unable to get to - restore factory settings Windows 7 installed.
On startup try pressing F8 repeatedly. Try last known good configuration from there. If that doesnt work, let the computer go to safe mode, then select the start orb and search "system restore". Go through the on-screen instructions to restore your computer to an earlier point. If all this is still unsuccessful you might want to take the computer into your local computer repair shop. (It may be hardware i.e. hard drive)
May 03, 2011 | Computers & Internet
Wont start up has power but when i start just times out and goes off
Battery is not fully charging or has failed. (replace and recharge) Also, CPU may be overheating/failing. This requires thorough cleaning and vacuuming of the laptop. I would suggest professional service. Disassembling a laptop is not for the first timer by any means! Finally, there is a chance that the power connector at the rear of the laptop is beginning to loosen at the PCB where it is soldered in. This is a common failure point, and again, sadly requires professional repair. As you can see, all roads pretty much lead to a professional close-up evaluation.
Jan 11, 2011 | Toshiba Satellite A205-S5825 A205-S5835...
On start up files never stop loading
Click on Start
Click on RUN
Type MSCONFIG
from the window Click on STARTUP tab
UnCheck all the programs related to Adobe,Java,Yahoo, MSN etc and Any update related programs,
Click Apply or OK, Restart the PC
Once you restart You will get a window of System Configuration. Click on Do not show me this window again.
Incase you find anything missing or going wrong after rebooting. Open MSCONFIG and put check on the application in STartup tab
Jun 26, 2010 | Toshiba Satellite A205-S5879 Laptop
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Spontaneously shut down
coolers are working?
on 3 months is a short time to get dusty but i see laptops after a half year whit coolers busted from heavy dust,
May 06, 2008 | Computers & Internet
Reloading windows 98 on a Panasonic Toughbook CF37
http://support.microsoft.com/kb/262381/en-us
Restart in Safe Mode and Use Msconfig.exe loadTOCNode(2, 'resolution'); Restart your computer, press and hold down the CTRL key after your computer completes the Power On Self Test (POST), and then choose Safe Mode from the Startup menu. For additional information about Windows 98 startup, click the article number below to view the article in the Microsoft Knowledge Base: 178548 (http://support.microsoft.com/kb/178548/EN-US/) No 'Starting Windows 98' Message at Startup After your computer restarts in Safe mode, use the System Configuration Utility tool (Msconfig.exe) to minimize conflicts that may prevent your computer from finishing Setup.
To start and use the System Information tool: 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Information. 2. On the Tools menu, click System Configuration Utility. 3. On the General tab, click Selective Startup, and then click to clear the following check boxes: • Process Config.sys FileProcess Autoexec.bat FileProcess Winstart.bat File (if available) • Process System.ini FileProcess Win.ini FileLoad Startup Group Items
Dec 05, 2007 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
