Question about RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01)
Setup rca dtv converter box
Don't have manual for remote setup. do have it hooked to tv can't get picture
  • 2 more comments
  • mary5541 Jan 18, 2009
    i losst the instructions to set the channels
  • Anonymous Feb 01, 2009
    do not have a instuctional manual to start the set up must have thrown away when taking it out of the box.
  • jonzer_420 Feb 09, 2009
    My remote does not work with my phillips tv, i need the code for programing a phillips tv to my rca dtv box remote
  • Anonymous Feb 18, 2009
    magnavox tv converter box is set up. can't get picture.
VOTIT
  • 2071 Answers
SOURCE: DTV hookup for an RCA XL-100 TV
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jan 08, 2009
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
pgh_pa_guy
  • 2992 Answers
SOURCE: I have this RCA Universal remote (RCU410WMS) and I
RCA's site list codes 25 and 006 for Magnavox cable boxes. Maybe one of these will work for the converter. The RCA site has a link so you can look up codes. Click on "find your remote control codes here" and pick your model number, then the type of device you want to control. If the codes I gave don't work, maybe try some of the other brands of cable box codes. You might find one that will work.
Posted on May 05, 2009
rcirone203
  • 70 Answers
SOURCE: RCA Converter auto shut down on TV with NO RCA Converter attached
You should check with the translator system. Sounds like it is on there end.
Posted on Jul 16, 2009
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Apr 28, 2009 | 1991 Honda Accord
Dtv converter box, no PS2
you need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
Apr 28, 2009 | Video Game Consoles & Games
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
Hope this may help;
Regards,
VOTIT
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
New Rca DTV converter / panasonic tv trying to get remote to work
You must set the code to conect your tv to your remote. The instructions are in your manual with a list of codes.
Nov 25, 2008 | Televison & Video
DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Oct 10, 2008 | Zenith C27A24T 27" TV
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01) Logo
260 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
