Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
GE Refigerator filter problem
My refrigerator is 3 years old. The water despinser was working fine until about three months ago after i changed the filter. The water began to slow down and eventually stopped. The water to the ice maker also stopped. I bought a new filter and this fixed the problem for several weeks, but the water started to slow down again and eventually stopped flowing. I just put a new filter in and the water is coming out just fine. I need to find out why the filters are clogging. They are expensive.
We have a GE Eterna side by side.The solenoid to the ice maker that switches from the cubed to the crushed ice has gone out. Now the fan in the freezer area is making a loud noise. It is only 2 years old. When my filter light came on the first time I changed it. The second time I have not replaced it, the water still dispenses fine. Yes, they are expensive filters.
Posted on Feb 08, 2008
  • 944 Answers
First thing to try is to cut open one of the old filters (ideally straight down the middle)and see if you can tell what is blocking it. Wear gloves and keep away from the stuff inside in case there is a chemical component - it should say on the packet of the filter if this is the case. You could also install another, coarser and cheaper filter in the water hose just outside the fridge - you usually can get a housing with a hose fitting on each end and a filter inside at most hardware stores. If you turn off the water pressure, cut the hose to the washer half way from the wall, then you can install the new filter with a couple of hose-clamps(Jubilee-clips). These sort of primary filters will remove any sandy or silty material in the water (you might not notice it usually from the tap) and also there is the possibility of algae/weed growth that is clogging the filter. It also might be worth calling your local water supply authority/utility and discussing the problem with them - they may want to come and check, or ask you to send a sample in for analysis. Some of what they can do, you can achieve yourself by putting a closed container of the water somewhere where it can get no vibration and waiting a week or so to see how much solids settle out. A tall thin container works best, as long as you can keep it dead still. Just possibly the filters are a defective batch, and it is coincidence that you got more than one - perhaps you bought them from the same small store? Also possible is that there is something in the pipe near the filter that is disturbed when you change one for a few days, then settles back into place blocking the hose - check there is not a small piece of mesh inside the water inlet hose connection at the back of the fridge - sometimes there is and these strainers can get blocked by something that behaves erratically. Hope this helps - please post again if not :)
Posted on Mar 29, 2007
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water flow is extremely slow after filter change.
Those filters are for refrigerators that have heavily treated water in the household. You could have a filter that filters your water supply and not use the filter inside the frig. Why use both? Now, if your home is not filtered, you may need it. Check to see if the water supply line is crimped somewhere or frozen when it gets inside the frig.
Jul 15, 2010 | GE Refrigerators
Water & ice dispenser problem
Ensure there is proper water pressure and volume to the unit....replace the water filter....all should be fine.
clarkco
Apr 29, 2009 | Refrigerators
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
224 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
