Question about Lexmark T632 Laser Printer
T632 lexmark getting dirt on printed pages
Pages are printed dirty on both faces, pages are turning lighly grey
You may want to changes the transfer roller also of your getting dirty on both sides. The toner may have leaked on the transfer roller also, causing this issue
Posted on Jan 09, 2009
  • 66 Answers
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Posted on Dec 19, 2008
Why will my T632 not print over Wi-Fi from my 2011 iMac (10.7.4)?
If the Lexmark T632 is already connected through the Ethernet, it will not be possible to connect it through wireless. The printer cannot be configured with both the Ethernet and the wireless function enabled. The printer will choose the physical connection (Ethernet / LAN) over the wireless connection.
Aug 03, 2012 | Lexmark T632 Laser Printer
How do i find out what my current page count is on the Lexmark t632
Print a menu page:
press menu right button until utility menu is displayed, then press select (lcd display print menu), press select again and the printer print the menu page, where you can see all the parameters.
May 19, 2011 | Lexmark T632 Laser Printer
I have a Lexmark x543 printer and when I print a document from MS Publisher, there is a small border around the edge of the doc. I have change my printer settings to Whole Page printing but it does not...
try to print a test page .. if u get the lining there then its a problem with the printer drum .. u might need to get it replaced .. if not then its an issue with the settings .. you can also try to reinstall the drivers in that case.,
Oct 21, 2010 | Lexmark T632 Laser Printer
Dark spots on prints
Typically spots on a page can be either caused by a flaw on the drum inside the toner cartridge, or the fuser asm which is included in a maintenance kit that can be ordered from Lexmark.
Sep 15, 2010 | Lexmark T632 Laser Printer
With my lexmark t632 the pages are printing with toner all over and I need to clean it but how do I go about that?
Hi. Try this. Remove the cartridge and use a lint free cloth to wipe it clean, should issue persists it could be something else causing it .. most likely the photoconductor, worst case if fuser. Hope this helps.
Mar 12, 2010 | Lexmark T632 Laser Printer
How do I print config pages for Lexmark T630, T640, T632, T642, and T650?
1 Make sure the printer is on.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Print Menus, and then press Select to
print the page. The message Printing Menus appears on the
display.
4 Verify that the options you installed are correctly listed under
“Installed Features.”
If an option you installed is not listed, turn the printer off, unplug
the power cord, and reinstall the option. See Step 3: “Install
memory and option cards” on page 30 for more information.
5 Verify the amount of memory installed is correctly listed under
“Printer Information.”
6 Verify that the trays are configured for the sizes and types of
print media you loaded.
or
3 Press Menu until you see Print Net Setup, and then press
Select to print the page.
4 Check the first section on the network setup page and confirm
that Status is “Connected.”
If Status is “Not Connected,” your LAN drop may not be active
or your network cable may be malfunctioning. Consult your
network administrator for a solution. Afterward, print another
network setup page to verify connection to your network.
or
1 Launch the CD.
2 Click Quick Reference.
3 Print the documents.
The same Quick Reference pages are stored in the printer. To print
them:
2 Press Menu until you see Help Menu, and then press Select.
3 When you see Quick Reference, press Select.
Sep 25, 2009 | Lexmark T632 Laser Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
Print head replacement lexmark t632
You will have to remove the top cover, both side covers and the rear door and redrive to get to it. Once these covers are removed you will need to remove three screws to release the printhead and disconnect a couple of cables.
I usually have to clip a couple of zip ties and use needle nosed pliers to get the cables out.
It is do-able if you are patient.
Nov 24, 2008 | Lexmark T632 Laser Printer
Lexmark T632 Laser Printer Logo
498 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
