How to remove Olevia 437 base???
Good morning
It is Dec 18, 2008. I wrote to Olevia technical support last month using the webform and have not received a reply. We need to obtain technical support for our 437 model. We have not been able to remove the base in order to hang it on the wall.
If anyone knows how to do this, please reply!!!
I know its been awhile but you have to lift on base while unscrewing... Couple of seriously long bolts that eventually stop when unscrewing.. lift and put pressure to continue unscrewing
Posted on Dec 03, 2010
WHEN I PLUG IN MY OLEVIA 437-S11 TO ANTENNAE I GET NO SIGNAL WHEN I KNOW THAT I HAVE ANTENNAE SIGNAL? HOW TO FIX?
the input for the TV has to be set to antenna .usually in the main menu.and perhaps do a channel search .
Oct 04, 2015 | Olevia Televison & Video
Need olevia 437 S11 firmware
There is no firmware to this TV by internet. Contact the nearest authorized service center for help.
Aug 21, 2012 | Syntax Olevia 537H Television
I have a olevia 37in model 437-s11.the power light is on but no pictures
I just bought one used and I plugged it in.. blue light on.. why iss it not working ? blue light off when tv on.. this work for this caveman.
Jan 23, 2011 | Olevia Televison & Video
My tv wont come on like no power try everything got it on mon but turned it off last nite but it would not come back on this morning
Possible that there are problems in the SMPS section or dry joints in the power or main board that fails to connect unless you are leaving it to warm up.
So if you are capable then remove board, solder all sections suspected of dry points.
Check the tips below for some help.
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
http://www.solder.net/technical/tips.asp
Nov 02, 2010 | Olevia LT42HVi 42 in. LCD Television
Olevia 437-s11 is stuck in stand by mode, I tried the solution provided but I'm unable to find the firmware in the olevia page. do you have any idea where can I get it?
It's not a firmware update, you do have a problem with the main board giving the power supply an ON command. Please have it looked at by a qualified technician.
Nov 20, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Tv repair
I soudcs like the backlight inverter board is bad or the power supply is npt supplying 24vdc to the inverter board.
Oct 31, 2009 | Olevia LT37HVS 37 in. LCD HDTV
437-S11 Change Channel and Volume Mutes
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 02, 2017 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia tv model 437-S11 that won't power up.
Hi there
I solved my problem by downloading new software from I can't remember the website (it's been about 5 months) and loading it via USB cable. I can't believe it worked but it did. You should try Google search and look for troubleshooting tips for your tv. Include model and serial numbers. When you download new software make sure you have the correct software version and find and follow directions as to how to get it done. Let me know if it worked for yah...Good luck and a happy new year.
Dec 30, 2008 | Olevia LT23HVX 23 in. LCD Television
POWER PROBLEM
LCD tv goes black and has to be restarted
Oct 06, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
