Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60 inch fresnel screen
My brother put his fist through the screens on our 60 inch projection phillips tv a few years ago. I ordered all 3 new screens from a small company and only received 2 out of 3. I'm missing the fresnel screen. I called phillips a number of times over the years to get a new one and they've told me they no longer make them! How does a company no longer make its own product! Does anyone know where I might be able to get this screen?? Thanks so much!
Tadi
  • angeltadi Dec 21, 2008
    i bought it from BJs in 2004! So its not really that old! I'm so blown about this situation!
  • ladywinn
    ladywinn May 11, 2010
    How Old is your tv alot of companys are disconn parts, anywhere from12 to16yrs old,the reason is out with the old in with the New HD Televisions!
  • Philips Master
  • 5,138 Answers
Your best bet is to try local TV shops to see if they have any and look on e-bay you may find one there or Place a add in Paper on wanted for tv ?You never know when someone has the same set as yours and lighting hits and most shops sell used screens ,ect what ever is good lefted on set.Have you look under repair service that is listed here on FixYa? Contact some of these shops listed on it! maybe someone has it.Good Luck .
Posted on Dec 21, 2008
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
My boyfriend was bringing our new 60 inch television home. he put a tarp over it and it scratched the screen. what can we do???
There is not much you can do besides replace the screen. Go to www.encompassparts.com There are 2 screens together on the front. The outside screen is the lenticular sceen and the inside screen is the fresnel screen. Thanks
Oct 29, 2009 | RCA P61927 61" Rear Projection Television
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Nov 08, 2008 | Mitsubishi WS-73713 73" Rear Projection...
65 inch Mitsubishi replacement screen? (WS-65311)
I think I can help you out if you still need that screen, I have a new screen, both fresnel and lenticular lens in a frame for a ws-65411. contact me at jgrisz@comcast.net
May 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Needed Fresnel Screen
What size screen? That model comes in 43,50 52 and 60 inch models.I have a source for the 43 and 50 inch models.
Mar 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Need a screen cover for 60 inch philip
Hello lcastillo225,
I think that you just called my shop, well in any event what you need to do is to contact the manufacture and order the part from them. The part is called a fresnel screen. Give them the make and model of your set and they will send you the part once you order it, however I would suggest that you get a qualified TV Technician to install the fresnel once you receive it. The cost will be around $150- $350 (average based on industry installation prices) for labor.
I hope this helps,
Thank you,
Shuttle83
Jan 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
55 inch projection tv
BUSTY35,
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
...........................................T.
Dec 17, 2007 | Televison & Video
Lenses
The screen with the "swirls" on it is the fresnel lens and that is the one that goes in back then the lenticular lens goes next (it has the feel of a grid to it). Then the screen proetector goes on the very front. The fresnel lens only works installed one way. On Sony TV's look for the orange tag with the part number on it and put that to the lower right facing outword and usually 99% of the time this is how they go back in.
Feb 18, 2007 | Sony KP-51WS510 51" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
501 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
