Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
Emachine t5026, 3 beeps
The computer comes on, the blue light on the front is on and the fans running like crazy but there is no image on the monitor. i tried another monitor, then i hooked the monitor to my laptop and the image showed. it has 3 beeps upon power on. i know this tells me what the problem but don't know what. please help kristie
  • dbittick Feb 06, 2009
    having same problem. 3 long beeps, nothing on screen but box to say screen working properly, but nothing else. I have the dsl hooked up, it works. Hard to fix 64 mem problem? Something maybe I can do? Computer tech needed?
  • 3 Answers
Beep Code Manual
3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
Posted on Oct 30, 2008
Yes thank you shayna it was the memorie card problems, that why not show on screen only hear beeping sound
Posted on Feb 24, 2008
Behind the cpu is a 4 pronged power cable try unplugging it
Posted on Jan 08, 2008
  • 42 Answers
3 beeps = ram error, possible a ram card busted, check ram cards on another pc whit memtest or another memory tester
Posted on Oct 22, 2007
Try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Posted on Mar 29, 2007
  • 64 Answers
Here are the beep codes for different manufacturers: http://www.computerhope.com/beep.htm
Emachines=Junk
Buy something else.I have mine around 4 years and nothing but problems after the first 2 weeks.Now it turns on fan runs like crazy and nothing on the screen.Solution,Take hard drive out,throw the tower in the garbage and buy something better.I have not heard one good word about emachines.When I asked my computer guy about emachines he laughed,that said it all right there.
Posted on Feb 22, 2009
Emachine T2672 will not recognize monitor
First, check to see if the computer is actually running--look for the lights on the front and listen for the fan (also, put your hand behind the machine to see if you feel air coming out). Once you determine that the computer is actually running, look at the monitor. Is it on? Is there a green or yellow light? If not, be absolutely sure it's plugged in both to the monitor and to the computer and the power source.
If you have a yellow light and the computer is running, it might be the video card. If there is not yellow or green light, the monitor is bad.
Find a friend who has a monitor and borrow it. Plug it into your system and see if it works. If so, the problem is your monitor. If not, then the problem lies in the computer.
Jan 26, 2009 | E-Machines eMachines Monitor E15T4
Monitor on emachines computer is black and the on/off light flickers screen will not come on
First make sure the power cord is plugged in both ends (in the wall and in the monitor).
When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow.
A monitor light that just flickers and goes off is probably an indication that the monitor has failed.
I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Jan 22, 2009 | E-Machines eMachines Monitor E15T4
T1150 emachine Computer not booting up correctly
did you hear any beeps from the bios? Try to remove all the peripherals like all the PCI cards, specially the "video card", your ram's,. Once you removed and cleaned all of those, put it back,make sure that theres no loose connections and boot the computer.
Nov 29, 2008 | E-Machines T1150 PC Desktop
Unit will not Boot up
Make sure your monitor is plugged in and try again
Jul 07, 2008 | E-Machines eMachines Desktop PC
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
May 17, 2008 | E-Machines eMachines Desktop PC
Emachine w2686 no display when boot up
Couple things to check. First, check with different monitor. Their monitors are usually build by KDS and I think there was a bad series out there. Also check for any beep codes through speakers on startup, this can tell you bad ram or bad video out. Also try unplugging computer and removing CMOS battery inside (watch like battery). Lastly, If non of the above, a bad processor will allow the computer to come on but no beep, no boot, no nothing but fans and green power light. Hope this helps a little.....
Apr 25, 2008 | E-Machines eMachines W2686 PC Desktop
The crazy blue box
crazy stuff here.. it might be the display or the harddrive check the pins on the display cable. how old is the PC? and have you added anything to the computer to damage the motherboard? I suggest doing a system recovery it might solve the promblem.
Sep 12, 2006 | E-Machines eMachines Refurbished EMA...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
2,154 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
