Question about LG WFT1071TP Top Load Washer
My LG Fuzzylogic WFT9235tp toploader does'nt want to spin
I have a large family so I wash on economy cycle and all of a sudden
it does'nt want to spin - HELP
  • 749 Answers
SOURCE: LG Toploader Wash cycle won't work
check for the water seal first if it is leaking! if it does, then it might just be the one causing slipping.
Posted on Nov 14, 2007
johnny_20
  • 161 Answers
SOURCE: lg turbodrum model wf-t851
The motor that makes the whole thing spin is old which has been used for countless times, making it sluggish/slow. That's what happened to mine, so I had a repair man and have him fix it. Mine just needed some lubricating, and it went back to normal. Can't say if the same would work for you, but nevertheless, have a repairman take a look.
Posted on Jul 22, 2008
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
  • 500 Answers
SOURCE: I have an LG TopLoader
I believe you need to replace the Spin Solenoid. Your machine is not switching over to spin/wash.
It is a very cheap part to replace, and can be bought at your nearest Home Appliance Part Store.
Part Number: 5250FA1731L/P
Good Luck
* If you found this helpfull, please rate a 4 thumbs up, and leave a testimonial. :-)
Posted on Apr 04, 2011
richroth
  • 9472 Answers
SOURCE: pe error in lg topload fully automatic washing machine
What is the model number?
Posted on Nov 19, 2012
Splashing water during spin cycle
Failure of the water level sensor
Oct 10, 2017 | Fisher Paykel EcoSmart GWL15
Hi, I'm using Panasonic Aquabeat NA-F130T1.(13kg),Fuzzylogic,Toploading. It stops at end of wash mode before rinse and blinks U12 code. Pls advise? Thanks.
Hi there, I'm using Panasonoic F130T1 washing machine.
my problem is,the washing did'nt complete n the water remains in the machine.
Pls advice as how i could solve this problem,tq.
Azhari.
Jan 11, 2013 | Washing Machines
Does'nt drain or spin what is the problem
What is the model number of your unit?
Oct 31, 2012 | Kenmore Washing Machines
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
I have an LG TopLoader washing machine. It does not want to wash, it fills with water and drain the water but it does not want to wash. It is a 7.2kg toploader.
Good Luck
Apr 04, 2011 | Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
LG WFT1071TP Top Load Washer Logo
135 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Mike
Mike
reliableservice
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
