Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
Ghost images I am getting ghosting or shadow images especially during sporting events. I tried the image restoration and that did nothing. I unplugged the cable box and hooked the cable directly to the tv and the images were still there. Is this a fixable problem? Any help short of calling the tv repairman? Thanks in advance for any help. Mark
  • 7 more comments
  • Mark Pilewskie Mar 29, 2007
    I can't post a picture, however the best way to describe it is a body or shapes look like they have a grayissh black outline around them. It is more noticeable when there is a figure on a contrasting background, such as the tannish color of a basketball floor, and the players on it. It doesn't occur much or at all in closeups, it seems to occur more say on a panoramic view, half or full court view, vs. a closeup of a player shooting a free throw. Thanks for the previous response. Mark
  • Anonymous Dec 25, 2007
    Also having ghost images. It's most obvious with large text on the screen. A lighter image of any particular letter will be right next to the original letter.
  • tineust Feb 19, 2008
    same problem
  • kewlmodude Feb 23, 2008
    i have a ghost image around the outline of the persons on the tv or the words Its like a double image no matter what setting i put the screen on or what setting the image revision is on the auto is the best setting but every thing seems like its a nich off where its should be a little help
  • padamson Feb 29, 2008
    I have the same problem on my 2003 model. My set is out of warranty, unfortunately. My technician says that it's an optical block problem and the part at wholesale price is $1,200.
  • Anonymous Apr 24, 2008
    ghosting
  • mrweiss May 01, 2008
    same here
  • Anonymous May 02, 2008
    none
  • Richard Jun 16, 2013
    I called Sony and they said your TV is toast... I researched online and have the fix... contact me if you want it
    New Friend:
    Problem Solver:
Red Ghosting on Sony Grand WEGA KF50XBR800 Rear Projection HDTV.
This problem FIX was been published on this website back on August 11, 2008. I used the procedure successfully 2 or 3 times and haven't touched it since January 2010. My Sony is a 2002 model and had the problem pop up in 2009. Here is the procedure I found here in 2009 - with some clarifying editing.
Best Solution PROBLEM: Red Ghosting on
Sony Grand WEGA KF50XBR800 50 in. Rear Projection HDTV. (This may also work on the Sony Grand WEGA KF60XBR800 60 in. Rear Projection HDTV). This procedure was posted on Aug 11, 2008 on this website. I've used it two or three times. After the last reset I've not had to touch the TV. IT REALLY DOES WORK!! Plus, you don't need an expensive Service Call! 1. Power off -- let bulb cool. 2. On TV Remote: Push the Display - 5 - VOL+ - Power buttons (in quick sequence) to display Service Menu. 3. Go into the User Menu and set Auto Revision back to auto. 4. Put an image on the screen that shows the problem. The edges of a 4:3 aspect ratio signal or a vertical line in the picture usually displays the ghosting very well. It is a pinkish "shadow". 5. Use 2 to scroll through the categories to find D GM TG. 6. Use 1 to scroll through items in D GM TG to find V POS D. 7. Write down current value. 9. Use 3 and 6 number buttons on the remote to change the value to minimize the ghosting. You should only need to move it up or down a value or two. 10. Press Mute - Enter to save the changes. 11. Power off and let the bulb cool.
Posted on Dec 09, 2014
I just got my ghost problem resolved by getting a technician to come by and all he did was to reconverge my TV.
The pictures are much clearer and the ghosting images seems to have been corrected.Give it a try and yours should be good again.
Rich.
Posted on Dec 31, 2007
    President:
  • 1,284 Answers
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Posted on Mar 29, 2007
I want to format my hard drive
If you have a true image to restore from, as like what is created with Win7 Pro Backup, or from Norton Ghost, you should be able to make a total restore. The destination drive had to be the same size or larger than from the drive the original image was taken from.
With Windows, you will require the image recovery DVD disk that are created using the OS that the image was generated from. With Ghost, you will require the Ghost recovery DVD disk to restore the image.
Jerry G.
Nov 19, 2011 | Computers & Internet
Self installing image
Try Acronis True Image. Similar to Ghost but works better. You can create an image of your system on a separate partition. When booting your system, you can recover from this image by pressing F11. Sort of like the hidden partition some companies put on a hard drive to return it to factory state. Only you create the partition yourself.
Aug 08, 2009 | Computers & Internet
Norton ghost 14... I cant recover back up...
Ghost saved the drive information in an image file.  Whatever you named your backup you would see *.gho, *001.gho, *002.gho.  That is your whole hard drive in a spanned image file.  Ghost Explorer is what you need to open and view these images and you would be able to extract files as your would from a zip file.  There are no restore points as you would think using Windows Restore.  Only the raw hard drive information as it appears on your dive now.  I'm  not sure if Ghost Explorer is provided with the home edition as I'm used to the enterprise for my work.
let me know if this helps
Apr 30, 2009 | Symantec Norton Ghost 14.0: Windows
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Blue ghost
I have blue ghosts/shadowing at the top of the screen.
Sep 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Why restore ghost image
You will need to restate your problem in better english.
Jan 07, 2008 | Symantec Client Migration 3.0 Add-On to...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
548 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
