Question about Dacor Epicure ER48D Stainless Steel Gas Kitchen Range
I want to install a 48" dual fuel range and I need to know the voltage and amperage to get the proper outlet and plug. It is also set up for propane and I'm hooking it to natural gas, I'd like to know if I have to change the regulator. Thanks
  • peymar1 Dec 22, 2008
    It is Dacor Epicure 48" dual fuel. Electric ovens and gas top burners.
    Problem Solver:
  • 17 Answers
YOU DON'T SAY IF THIS IS A DACOR CONCEPTS PRODUCT OR WHO MAKES IT..
IF IT IS, CALL THESE NUMBERS..
Dacor 1440 Bridge Gate Drive
Diamond Bar, CA 91765 Toll free: 800-793-0093 Main: 626-799-1000 Fax: 626-403-3130
Posted on Dec 20, 2008
How do you repair oven that won't fire?
Given that its gas, I would advise you get a competent person to check it out. Propane gas and sparks don't mix. There are things in the owners manual you may feel confident enough to check, if not, leave it to a trained person.
Aug 29, 2014 | DCS Professional RDU485GDL 48" Pro-Style...
DC 4.5-30V 0-10A Dual LED Digital Volt meter Ammeter Voltage AMP Power
If you want to read just the DC VOLTAGE of your RV battery , with the multimeter in the proper VOLTS range , you would simply connect the red lead to the positive feed and the black lead to the negative feed and read the digital display of the meter.
Whenever you want to read DC AMPERAGE with a multimeter , first set the meter for it's highest amps. Then you must connect the meter leads in SERIES somewhere within the circuit. This means that you will have to first create an OPEN in the circuit and then connect one lead from the meter to one side of the open and the other meter lead to the other wire . For example : let's say we would cut one wire going to a light bulb and then we would connect the AMP meter between the 2 ends of the cut wire , we could now read the AMPERAGE or SERIES FLOW of the current that the bulb draws when it is powered on.
Remember , NEVER connect the AMP METER directly across a powered circuit. It's like putting a direct short across the circuit.
Be sure to select the proper AMPS range setting on the meter before connecting the meter to a circuit. I recommend starting with the HIGH amps setting first to get an idea of just how much the circuit being tested actually draws when it it powered on. If you would happen to first start with a lower amps range , you might blow the protective fuse located usually inside the multimeter. Do no exceed the range of amperage that the meter is rated for.
May 11, 2014 | Vehicle Parts & Accessories
Gas cooker
Probably. Speak with your propane supplier about what will need to be done with your stove.
May 03, 2010 | Belling DB2 Dual Fuel (Electric and Gas)...
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
48" dual fuel burners clicking wont stop after lit.
just remove it from the board .
and please be carefull
.FRANKIE.
May 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Propane conversion
I used to order all my parts throgh a company called Arrow. It worked at a place of business that did LP & Propane conv. along with all installations so they may not sell to retail. You may also call Lowes, Home Depot or Sears and ask if they can get you the parts or know an installer who can sell them. Be careful.......they can be tricky and you could end up with a slight leak. They also take special tools. Incase you wern't sure or didn't know. Just be sure to test all installed new parts with the soap & water test!
Apr 26, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Viking dual fuel range wiring
You will need a neutral, ground and 2 wires carrying 120V each
Dec 27, 2008 | Viking 48" 6 Burner, Grill Professional...
Need electrical information for electrician to install new power
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
Dec 01, 2008 | Jenn-Air JDS8850 Dual Fuel (Electric and...
I have a viking rangetop and the griddle's gas is not turning on the glow plug works fine but no gas seems to be coming out.
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
Sep 06, 2008 | Viking 48" 6 Burner, Grill Professional...
Why does the range give us a caution that the range has been setup for propane.
stove comes from the factory set for natural gas, be sure your not reading a sticker that would affix to the range after you convert it
Mar 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Dacor Epicure ER48D Stainless Steel Gas Kitchen Range Logo
131 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
