Question about Apple iMac G4 Desktop
EMac Screen Resolution
EMac. After doing a clean install the monitor is only displaying an eight inch square window. Under display, it shows two screens. One is 640 by 480 and the other is 1024 by 768. Neither can be modified. Will disassemble if required. Thanks
  • Loteck Dec 26, 2008
    Thanks for the reply. When I did the clean install I forgot to load the updates. Did that and everything is fine now so it was a software problem. I am able to buy these eMacs locally from a computer re-cycler for $30.00 and with a little work they do fine. The biggest problem they have is they only have one IDE bus. Removing the bottom cover exposes the IDE bus, memory and battery. I'm able to switch between a hard drive or CDROM drive as needed with longer cables. Anything connected this way must be set as slave drive. For the cost I can live with this minor inconvenience.
  • 368 Answers
Hi Loteck,
In my other life, I do computer support for a major metropolitan school district. We've had quite a few eMacs that have been coming in with bad displays. We don't even try to fix them any more. They get the Airport cards, CD drives and any other spare parts like RAM upgrades pulled, then get recycled.
Probably not the answer you're looking for, but with most technology, there comes a time when fixing it isn't worth the trouble, unless it's your hobby. I wish you good luck and a better answer if it exists.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Posted on Dec 24, 2008
Samsung screen is not calibrated properly. There is a line on the right side of the screen that I can't get rid of.
Unfortunately the line didn't show up in the video.
1) New LCD screen?
Should have an Installation CD Disk that comes with it. Use it if so.
Has the Drivers on it.
Driver: Small piece of software that allows the Operating System to communicate with a device.
Don't know which version of the Windows O/S you have.
The device in this case is the LCD monitor.
2) What is the NATIVE screen resolution for the LCD monitor.
Look up the specs on the monitor using it's Model Number on back.
For example I installed an HP 2009M 20-inch widescreen monitor, along with the 26-inch RCA ENV HDTV I use for a monitor.
I had to use the drivers from the disk, but could still not set the native resolution in Display Properties.
There is an alternate resolution to the native one that can be used.
The drivers from the disk made it so.
The 20 inch widescreen is 1600 x 900 (Pixels)
The 26 inch HDTV is set at 1360 x 768 (Pixels)
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
In the Display Properties window click on the Settings tab.
What is the Screen resolution setting? What is it supposed to be?
The Slider on the line is clicked on with the left mouse button, left mouse button held down; then the Slider is slid to the left to decrease screen resolution, or to the right to increase with the mouse.
Color quality should be set to High (32-bit)
1) Installing software (Drivers) from the Installation disk, (Or from the monitor manufacturers support website);
2) Setting the screen resolution;
doesn't help, replace the monitor cable with a known to be good one.
Still no? Your LCD monitor is going out.
Dec 07, 2012 | Computers & Internet
How to change your Windows 7 display settings In Windows 7 there are serveral...
In Windows 7 there are serveral ways to get to your display settings. I have detailed them below in options so that you can access them as needed.
Option 1
Right click on your desktop and select "Screen Resolution"
Option 2
1. Right click on your desktop and select "Personalize"
2. Next click on "Display"
3. Click on "Adjust resolution"
Option 3
1. Click the Start button and click Control Panel
Once you are in the Screen Resolution you can set the resolution you want.
Note the resolution that is set now is a wide screen resolution. If you have a standard monitor the equivalent resolution would be 1280 x 1024.
After you have made the needed changes click on Apply then OK to save your changes.
Note if you are still have trouble with your monitor displaying right you may need to install the monitor drives. Windows is not going to have the actual drivers for all monitors. So in picture below you will see where is shows "Generic PnP Monitor" this means that the computer is using a generic driver. You can access this screen by clicking on "Advance Setting".
If you need to install the monitor drivers the link below will take you through the steps of installing the monitor drivers.
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
Yesterdy i was working on an optical drive issue with a comp, got it done by removing an extra drive from this computer...but...the video on this computr is not wrkong now...what issue? what is the...
What is the Resolution
Refers to the sharpness and clarity of an image. The term is most often used to describe monitors, printers, and bit-mapped graphic images. In the case of dot-matrix and laser printers, the resolution indicates the number of dots per inch. For example, a 300-dpi (dots per inch) printer is one that is capable of printing 300 distinct dots in a line 1 inch long. This means it can print 90,000 dots per square inch.
For graphics monitors, the screen resolution signifies the number of dots (pixels) on the entire screen. For example, a 640-by-480 pixel screen is capable of displaying 640 distinct dots on each of 480 lines, or about 300,000 pixels. This translates into different dpi measurements depending on the size of the screen. For example, a 15-inch VGA monitor (640x480) displays about 50 dots per inch.
Printers, monitors, scanners, and other I/O devices are often classified as high resolution, medium resolution, or low resolution. The actual resolution ranges for each of these grades is constantly shifting as the technology improves.
Solution :
If you not get the proper video image in your screen that mean you have remove the driver of video, for installation the driver, put the Driver -CD in rom, and start the setup is simple set you get the driver.after installing the driver restart your PC
If you change any display setting then also you get the occur.for set the resolution go to the control panel and select the Display and go to setting tab set the ' Screen resolution" as before.
If you still not get the display then open you PC and remove the RAM and put again,and try again.
God Luck
Sep 15, 2011 | Asrock P4I45GV R5 Motherboard
The display of my monitor (hp w1907) is widened. A circle looks like an elipse. How can i solve this. please help.
It might tvhat there are no video drivers on the PC or there screen resolution is too big or too low
Screen Resolution Issue
Windows XP
1. Click Start -> Control Panel -> Display
2. Display Properties should appear
3. Click on the Settings Tab
4. Slide the Bar to the Left or to the right Making the picture almost a square
Windows Vista/ Windows 7
1. Click Start -> Control Panel -> Personalization
2. Click on Screen Resolution
3. Move the bar up or down until the picture turns almost a square
Or else reinstall a new video driver configure the screen resolution again
Hope this helps
May 24, 2011 | HP w1907 LCD Monitor
I had to reinstall my Viewsonic monitor after getting a new hard drive. Now the screen shows everything is a horizontal stretched mode. How do I get it to normal aspect ratio?
It seems like the display resolution was not set to the optimal resolution for your monitor.
To correct this, follow this guide. I am assuming you have Windows XP.
1) Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
2) In the Control Panel window, open Display.
In Microsoft Windows XP, depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
3) In the Display Properties window, click on the Settings tab.
4) Slide the Screen resolution slider all the way to the right for your optimal resolution.
5) Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
NOTE: If the text appears too small, go back to step 4 and try a different position on the slider until you get it how you like it.
Good luck on solving your computer problem.
Aug 27, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Upgraded eMAC G4 to OS 10 and have display problem
You SHOULD be able to control the monitor adjustments in os 10. In the Displays section of the System Preferences, look for the "geometry" tab. Under this tab you should be able to control width and height so your display fills the entire screen.
If you still can't find it, try adjusting the resolution and refresh rates. Also use the "detect displays" button.
Jul 15, 2009 | Apple Computers & Internet
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
I'm not able to download the solutions disk (version 31.1)
Sorry this is a late response - I just had the issue with the T1i solutions disc ver. 20.0. on Windows XP
Right click your desktop and select Properties
Go to the Settings Tab
Under "Display" you should see it is selected to your default monitor or Plug and Play monitor.
Under that, you will see Screen Resolution on the left hand side. If the slide bar will not allow you to change this any higher, then at the bottom of the window you will see an option for Advanced
Write down your current screen resolution so you can change it back after installation is complete.
Click on Advanced - You will see tabs at the top - click on the tab marked "Monitor"
This will show you Monitor Type - under thatyou will see Screen Refresh Rate (ex. 60 hertz)
Under that is a check box marked "Hide modes that this monitor cannot display"
Uncheck this box and click "OK"
This will take you back to the screen resolution and you can change it from there. Change it to 1024x780 - this is the minimum display resolution for the installation disk.
When you have installed the software, you will want to change it back to your normal resolution
Note - if you want to use the EOS utility to download and edit your pictures, you will need to change it back to 1024x780. I just use the Windows Camera/Scanner wizard to download, and then use Adobe to edit the photos.
Hope this helps!
Dec 30, 2008 | Canon Cameras
Apple iMac G4 Desktop Logo
237 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
