Question about JVC KD-S6060 CD Player
Reset radio when comes up with safe
My car has just come back from the garage i turned the radio on and it says safe and wont come on i have tried pressing the buttons with no joy as i dont have a manual
  • 27 Answers
Car stereo not working,, could be in safe mode ?
Sorry to tell you this needs to have the code reset once you remove the battery the stereo needs to be reset only a garage can do that there is no doubt about it. Hope this helps Best wishes, Malcolm Campbell.
May 09, 2017 | Vauxhall Cars & Trucks
Since i changed the battery the radio says 'safe' but wont work!
usually if a radio says "SAFE" then it is one of two things
1. a factory theft deterrant
2. a power spike tripped the internal surge protector (common if having battery or alternater problems)
here are some possible solutions for the respectively numbered problems
1.) google search (or whatever your favorite search engine is) for a factory reset code for your specific
radio manufacturer this may be model specific if your vehicle has the OEM (stock) radio then you
should be able to find the code by searching for (vehicle make and model) audio reset code or radio
security code
2.) remove the fuse for the radio and any aftermarket audio devices you may have installed.press the
power button on the radio (if it has knobs then turn it on for a moment and then back off) replace
fuses.
Jun 12, 2011 | Car Audio & Video
Good day. I drive a 2007 City Golf, I recently took my car in for its service. When i received the car back the radio was saying SAFE?? What does this mean? I Bought the car at a second hand car dealer and...
the radio anti theft system is operated when,for any reason, the power is turned off/disconnected,(safe mode)in some markets,the dealers do not keep the factory code (0000) OR the code inputed by the owner...SO, if anybody turns the power off(disconnects)the radio DIES....and garages will then charge you to "repair" it.
the garage would have known this but i cant see them offering to pay for disconnecting your battery.....
the only alternative is a specialist radio shop who may be able to
short the code out..in england the company is "radioactive" and they charge £15.00 at your house.....
Sep 02, 2010 | 2007 Volkswagen Golf
My service engine light has been on forever. How do I get it off? The car runs just fine. Have never had a problem with it.
If the light was flashing when it came on, then it means your engine is misfiring.
A solid light can mean anything from a loose/faulty gas cap to a transmission issue.
This light comes on when the computer detects a fault of some sort in its diagnostic tests. If it keeps detecting this issue, the light will remain on. If the light turns off, then it has detected that the issue may no longer be present.
In order to find out what the exact reason was for your light, You need to have your car computer scanned to retrieve the code that the computer would have stored when the light triggered. Most garages will do this free of charge. The code will tell you what may have caused the light to initially turn on.
You can try resetting it by disconnecting the battery for about 10 mins (make sure your radio doesn't lock out though as you'll need a code to use the radio again if it has a lock out feature). You can also have it reset by garages when you have it checked for the code (some garages charge to reset the code). The light will most likely come back though if it's been on for such a long time as it seems to be an ongoing issue
Nov 13, 2009 | 2005 Chrysler Pacifica
How do I reset my ml320 stereo code
what is radio code 4 a 2000 mecedes ml 320
Sep 09, 2009 | 2007 Mercedes-Benz ML320 CDI
BMW 318 would not start this morning Error code 2BOA?
I think you need a new battery.
Replace it and the radio will probably reset ok when you input the code..
Jul 09, 2009 | 1996 BMW 318
Radio in safe II mode
try disconnecting the battery overnight. that should put it back in safe mode 1.
Jan 09, 2009 | 1995 Audi S6
How to reset the check engine light on a 2002 toyota highlander. it happens everytime they disconnect the scensor tube to get to the air filter. thanks, susan
That means that the sensor must be replaced.
You can turn temporarily off the light by disconnecting battery for five minutes, but it will probably come back.
To fix it completely, take it to a garage and have the problem fixed.
Note: when you unplug battery you may be asked car radio security code afterward.
Oct 10, 2008 | 1992 Toyota Celica
Jvc kd-66060 cd player problems
if the car battery had gone dead while it was in the garage you may have to press the reset button on the radio( if there is one, it would be behind the face and there will be raised print that says reset) if there is no reset button you can unplug the radio harness for about a minute or so to reset it.sometimes the fuse for the 12 volt ingnition can be the problem( on your radio it would be the fuse connected the red wire-if it is ejecting and giving you display the fuse connected to the yellow wire is good-
Oct 22, 2007 | JVC KD-S6060 CD Player
JVC KD-S6060 CD Player Logo
75 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
