Question about Insignia LCDTV26 26 in. Television
YOU CAN ONLY CHANGE MANUALLY TO CERTAIN CHANNELS AND ONLY MSNBC H
We have a jvc television bought in 2001. our daughter selected the channels available in her area. Our cable service is different and we are only able to get certain channels and only one channel with sound...msnbc. How do we clear this off so that all channels are available?
  • 89 Answers
You need to auto program the TV. this is done in the menu. If you are using cable you should make sure that you select CATV prior to auto programming
Posted on Mar 13, 2009
Jvc gennessa how to scan for channels
need to know if a cable box is used. If using the built in converter there are more than 1 positions that can be selected. On one setting some channels are omitted. A channel scan is usually on the remote that came with the tv. It is under the menu option to do a channel scan.
If some are skipped try to manually put the channels in to see if anything is there.
Mar 19, 2013 | Televison & Video
My TV will not change channels it seems stuck on channel 2 This is true with the remote and with the buttons on the set.
Try to change the channel by manually putting the numbers in with your remote. If this works then you probably need to program your channels.
Aug 21, 2010 | JVC AV-27220 TV
JVC AV-20FD24 will not pick up the signal from the antenna. I Moved tv from my daughters apt to my home and now it will pick up only 67 , 69, 27, 57, & 25. I am currenty using an antenna on top of...
On the JVC remote there should be a setup button. Sometimes they call this Main. Regardless, once in setup you'll need to change the input from cable to antenna. This should solve your problem.
Oct 12, 2009 | JVC AV-32D305 32" TV
Channels won't change on tv with remote or manually
hi,you need to auto search first your your t.v set if nothing happen possible defect is the tuner.
Aug 03, 2009 | JVC LT-32P679 32 in. LCD TV
Jvc av-20cm5 channel programming issue
you have a programing error in the main control ic it ca be repaired but its $$$$$$ my guess is 150.00 -200.00 the control ic has a modified control memory the memory is held in place by a charged capacator if you unplug it and leave it for a week and plug it back in it might be ok for a while if not try unplug it for a month . that might be enough for a reset but the problem will keep comeing back the chip is damaged
Apr 01, 2009 | JVC Televison & Video
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
solutiondoct
Jun 15, 2008 | Samsung HP-T4254 42 in. Plasma Television
Auto channels
is there MENU KEY press it then enter and install or tunnig option choose it and tune which channel you want
Feb 10, 2008 | JVC AV32F577 32" TV
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
Insignia LCDTV26 26 in. Television Logo
143 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
